Cobb AP Datalog - Knock Retard - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
post #1 of 5 (permalink) Old 02-15-2014, 08:37 PM Thread Starter
mazdaspeed14158
Points: 189, Level: 3
Points: 189, Level: 3 Points: 189, Level: 3 Points: 189, Level: 3
Activity: 15%
Didnt know where else I should post.
So here goes.
2007 ms3 Stage 1 Cobb AP tune with cpesri.
My AFR's are fine as with everything else except my knock retard.
Please advise, or direct me into a location where an advisor can assist. I am used to subaru tunes with cobb and Subaru's rarely knock such a high stat.
https://skydrive.live.com/redir?resi...nt=file%2c.csv
datalog4.csv
mazdaspeed14158 is offline
post #2 of 5 (permalink) Old 02-15-2014, 09:07 PM
swerv0428
Celest Zoom-Zoom
Points: 18,452, Level: 86
Points: 18,452, Level: 86 Points: 18,452, Level: 86 Points: 18,452, Level: 86
swerv0428's Avatar
everything looks good like you said except the knock. Is this the only time you have noticed the knock being high? Maybe try taking another log and seeing if it is still there. Keep the knock retard up on you display of your AP and see if it was just a one time thing.
also I moved the thread into the first gen speed section.
swerv0428 is offline
post #3 of 5 (permalink) Old 02-15-2014, 09:18 PM Thread Starter
mazdaspeed14158
Activity: 15%
I did two logs, knock was there both times. Just one time it peaked at 5 something, but yeah everything else looks great. Any suggestions on what to do or why it is doing it?
Also,
Thanks for moving thread to correct section.
post #4 of 5 (permalink) Old 02-15-2014, 09:52 PM
swerv0428
Celest Zoom-Zoom
swerv0428's Avatar
It's possible it could be a false knock. I'm not 100 percent sure what could be causing it. Based on you mods you shouldn't be getting knock that high.
What gear did you do the pull in?
Sent from AutoGuide.com App
post #5 of 5 (permalink) Old 02-15-2014, 11:34 PM
Frnchplayr15
Points: 79,334, Level: 100
Points: 79,334, Level: 100 Points: 79,334, Level: 100 Points: 79,334, Level: 100
Frnchplayr15's Avatar
Did this happen just once or a few times? Also do another datalog using all these parameters
Actual AFR
MAF Voltage
Boost
Mass Airflow
Boost Air Temp
RPM
Calculated Load
Short Term FT
HPFP Act. Press
Spark Adv.
Intake Temp
Accel PED POS
Intake Valve Adv.
Throttle Position
Knock Retard
Vehihcle Speed
Long Term FT
Wastegate Duty Cycle
INJ Duty Cycle
Coolant Temp
This can help with seeing whats up with your car. Did you buy the car used? When you did this datalog where were you driving?
2013 Mazdaspeed 3 Tech pack
M2 Performance Catless Long Downpipe // UR CBE // All bulb's are V-LED's // RA Mudflaps // STI 06-07 Chargespeed Lip // Rear LED Reflectors // Autotech Internals // COBB Accessport v3 // JBR OCC Stage 2 // JBR SSP Kit // JBR SSB // JBR Stage 2 Intake // JBR TIP // CP-E RMM // SPC Camber Arms // Forge BPV v2 // Hella Supertones // BC Coilovers // CS RSB // NGK IX Iridium 1SC Plugs // RPF1's 17x9 +45 // BFG Super Sport Comp 2 255/40/17
Next things to buy:
PMM and TMM
GV Grill
BNR S3
Guardian Angel from Stratisfied
FMIC
2010 Mazda 3 iSport- SOLD
WORLD CUP 2014 BRAZIL
Frnchplayr15 is offline
cobb , datalog , knock , retard
