1. I have not heard of anyone baking them apart yet. 2. Search, there is even a walk through on here...with pictures AND even a video 3. Personally, I have seen some do it, some not. I think removing it would not be a good choice. But that's just me.
__________________ 2010 Mazda 3 GT w/ Tech Check out the Saint Louis Mazda Facebook Group www.facebook.com/stlmazda | |||||||||||||||||
i don't think it's too common to paint the turn signal reflector, as it helps let people know your turning, but if your going for a certain look, dont think that will stop you from painting it these headlights are huge and don't fit in most ovens, i had to use a heat gun, its a lot easier with two people, one holding the heatgun and one with gloves/butter knife pulling it apart im assuming the tail-lights will be the same way i had to buy aluminum foil tape afterwards because i did a bad job resealing it by myself (i didn't use any clamps) and used the tape to add some extra seal for it | ||||||||||||||||||
I think someone was going to remove theirs but said it left a huge gap inside so they just painted it.. I would paint it but if I had the money, I'd get the new 2012 speed3 headlight. they have clear/white reflectors | ||||||||||||||||||
Don't try to open the tail lights!! They are plastic welded shut. More likely to destroy them (I almost did ) they are also very brittle and crack easily. Do unfortunately no painting of tails. unless u find a feasible way to do it, and if you do please let me know lolAnd on th other ones, I painted my yellow thing cuz its mostly just a reflector. And as far as opening headlights, I recommend using a heat gun on low heat, and a knife and flathead screwdriver. As you heat up an area try to wedge the screwdriver in enough that you can see the glue stretching and cut it. And work all the way around. Best to do with a friend. Be very careful not to melt the lens, and don't pry too hard because you may break pieces off which is bad news. Hope this helps
__________________ Mods: all silver and chrome painted blue metal flake and blue chrome respectively. headlight housing done in blue chrome, blue metal flake mirror caps, painted front lip blue. Pioneer AVH-P8400BH head unit. Pioneer TS-W259S4 10" subwoofer. volfenhag 1200W amp (will upgrade soon). blue footwell lighting for front and rear seats. TRS 35W HID's 5000K Morimoto Elite. Graphite painted rims w/ blue evil m. Last edited by Havocforming; 05-30-2012 at 09:17 PM. | ||||||||||||||||||
tails are flash sealed, can't bake them The headlights I had to use my heat gun on them. They are so large they don't fit in my oven to bake open. | ||||||||||||||||||
Wow, thanks for all the responses! Hmm I have a slightly oversized oven...maybe it will fit, I think I will paint the yellow thing. I am going to have an extra set of G35 tail lights soon - I am going to try to dremel those open, paint and reseal. If all goes well I will give it a go on the Mazda. I dont think that tint suits this car well, but if I painted the non reflective parts - (and I am thinking of something to do with the red brake light lens - will involve cutting and painting so no red is left) - that would look boss. | ||||||||||||||||||
Darkspeed blacked out his turn signal reflector but personally it doesnt look as good heres mine if this helps ![]() Tail lights can be done but it takes triple the time to open, patience, and lots of beer! Quote:
__________________ 2013 Mazdaspeed 3 Tech pack M2 Performance Catless Long Downpipe // All bulb's are V-LED's // RA Mudflaps // STI 06-07 Chargespeed Lip // Rear LED Reflectors // Autotech Internals // COBB Accessport // Corksport Springs // TurboXS Hybrid BOV Dyno'd at 266 HP and 302 TQ on Stage 1 93 OTS map Next things to buy: GV Grill JBR Power Path Stage 1 Intake COBB Cold Air Box CP-E Turboback Triton exhaust 2010 Mazda 3 iSport- SOLD Time before World Cup 2014 | ||||||||||||||||||
| headlight, inside, light, paint, tail |
