Hey guys. One thing I've always wanted to do was have a USB power source for a phone I have mounted directly behind my rear view mirror. I choose this location because I sometimes like to record my driving. However due to this the maximum amount of time one of my old android phones can handle is about 2 hours since the video app requires the screen to be on and the camera itself drains a ton of power. I can of course run the cable from one of the car power plugs but it's so ugly ![]() Anyway I found the guide on how to remove the overhead map light console here. I would like to have a USB 5 volt cable spliced into the overhead light power source come out as a female USB port out of the little hole in the picture below. ![]() So I guess my real questions are A) Is there enough power in there to even do this? B) How can I do this safely? If I got one of these can I hook it up to the overhead light power source or does it need to run to the back of the dash? Powerlink, Hardwired USB A in-car charger If this works out I would be glad to write a how to with pictures.
__________________ Mazda 3 2010 /w Bose Audio Last edited by Akujin; 06-10-2012 at 02:01 AM. | ||||||||||||||||||
It's all about voltage. Read this thread. Hard Wired Micro USB power for the Droid Someone posted this late in the thread linked above. http://www.mountguys.com/product_p/mfx5v-b-micro.htm Last edited by zmarko; 06-10-2012 at 11:34 AM. | ||||||||||||||||||
Or get one of these and plug into the center console cig lighter: Also, what you linked should work, but yeah you can hardwire it into the fuse box, I hard wired the power cord for my GPS unit, and just shoved the power cable into a "15" fuse slot. Using "Add a fuse" should work fine and should be enough for USB.
__________________ Last edited by fruitlewps; 06-10-2012 at 05:49 PM. | ||||||||||||||||||
| The Following User Says Thank You to fruitlewps For This Useful Post: | ||
Tomato88 (06-12-2012) | ||
__________________ Mazda 3 2010 /w Bose Audio | ||||||||||||||||||
Main thing you'll want to mind is current draw. Figure out how many amps or milliamps that phone charger draws and find out how the overhead light is fused. Check the fuse amperage rating and see if it's do-able to simply splice the charger into the same lead. If it seems the charger will draw too much for the fusing for the overhead light, then wire it's own power lead or use a larger fuse. | ||||||||||||||||||
Sent from my Autoguide iPhone app
__________________ CURRENT: Flat black 17in RAZE r74s on BFGoodrich g-Force Sport 215/40ZR17 // Painted front & rear emblems white // AW Switchbacks // 5000k LED on front bumper // QL-MZD723 Headunit // 35% front with 20% back Carbon tint // Custom welcoming LED lights under seats FUTURE: 5000k HID // Flat black vinyl roof // CORKSPORT Interior LED kit // Rear Lip Spoiler // Naked girl always in the passenger seat | ||||||||||||||||||
| Where would you leave the USB port dangling? I thought the whole point of this thread was to have a clean install? If you leave the USB port hanging from the headliner, you'll have the entire phone USB cord hanging in the way. And that doesn't seem like a real clean install IMO. If you tuck the USB port inside the headliner, swapping out cords for different things is gonna be a PITA.
| It wouldn't dangle but here's an arrow on the picture I posted before just to be very specific. ![]() It would likely come out maybe a centimeter or an inch.
| The Following User Says Thank You to Akujin For This Useful Post: | ||
ebags (05-02-2013) | ||
| lights, overhead, plug, power, source, splice, usb |
