Mine does this, too. I'll notice it when circulating the air from inside the car and also when using the floor vents from start. Use the A/C from outside air and that usually clears up any moisture within the minute.
Sounds good, we will give this a shot! | ||||||||||||||||||
I don't know if this will solve your problem or not, but we occasionally spray a bit of Ozium in the passenger floorboard area when we have recirculate on. I'm not talking about holding the spray button down for a long time, just a quick spritz or two maybe once a month.
Every car that I have ever owned with A/C does this. Not sure if it is the climate or what, but just roll your windows down for a second until the funk smell clears.
__________________ Have something you want to sell on the forum? Abide by the rules. Read them by clicking here | ||||||||||||||||||
Also make sure your AC drain isn't clogged (when it's idling in place with the AC on, do you get a puddle on the ground). If there's no puddle, then water is sitting in the AC system.
__________________ 2001 Ford F-250 Lariat CCSB - 4x4 7.3 PSD, HD4R100, PHP FU Chip, 4" MBRP XP series exhaust with muffler, Ford AIS intake, Zodad mod, Pioneer AVIC-Z130BT In-Dash Navigation, BOYO VLT-422C Back Up Camera, Glowshift 3 Pod A-Pillar (EGT, TFT, Boost), Scangauge II, Husky Liners, Husky Mud Flaps 2013 Ford Explorer Limited - 3.5L v6, 4wd, 301a package, Dual Panel Moon Roof, Tow Package, BLIS Last edited by Bryce; 08-08-2012 at 10:28 AM. | ||||||||||||||||||
Turn off the compressor but leave the fan on high so it will evap the moisture from the evaporator(inside the car) I'll have to see how this can be done on the car. I honestly haven't looked into it. Most cars you can hit a button to turn it off. | ||||||||||||||||||
| I don't know if you know but when you have A/C off and the fan mode directed to feet only and to the right the A/C compressor is still on! Switch to the left or mix with half feet half body and the compressor doesn't run. I've noticed this due to the fact of mpg drop and hearing it run still one day.
__________________ 2013 Mazdaspeed 3 Tech pack M2 Performance Catless Long Downpipe // All bulb's are V-LED's // RA Mudflaps // STI 06-07 Chargespeed Lip // Rear LED Reflectors // Autotech Internals // COBB Accessport // Corksport Springs // TurboXS Hybrid BOV Dyno'd at 266 HP and 302 TQ on Stage 1 93 OTS map Next things to buy: GV Grill JBR Power Path Stage 1 Intake COBB Cold Air Box CP-E Turboback Triton exhaust 2010 Mazda 3 iSport- SOLD Time before World Cup 2014 | ||||||||||||||||||
| mildew, smell |
