Headlight aiming? - Page 2 - 2010-13 Mazda 3/Mazdaspeed 3 Forums
Go Back   2010-13 Mazda 3/Mazdaspeed 3 Forums > 2010-2012 Mazda 3 News & Discussion > 2010-12 Mazda 3 Discussion
  #11 (permalink)
Old 10-06-2010, 02:21 PM
MUSHVROOM3's Avatar
MUSHVROOM3 MUSHVROOM3 is offline
Points: 3,033, Level: 33
Points: 3,033, Level: 33 Points: 3,033, Level: 33 Points: 3,033, Level: 33
MUSHVROOM3 is on a distinguished road
Originally Posted by mazdazoom View Post
I only found out when I switched out the factory lamps with Silverstar Ultra's...and was still dissapointed.
So I set about to remove that metal anti-scatter ring, which you can't do as the glass lens is sealed to the housing and thats when I found the adjusting screws to aim the fogs higher.
how's the fogs now with the adjustment? How high did you adjusted?
I was thinking about taking those rings out too.
  #12 (permalink)
Old 10-06-2010, 04:07 PM
mazdazoom's Avatar
mazdazoom mazdazoom is offline
Points: 5,335, Level: 46
Points: 5,335, Level: 46 Points: 5,335, Level: 46 Points: 5,335, Level: 46
mazdazoom has a spectacular aura aboutmazdazoom has a spectacular aura about
I have them all the way up....still not what I expected but it is better.
Some of the guys have opened the headlight housings to paint the inside by heating them in the oven, so that could work here to get at that ring but I'll draw the line there and live with what I have.
Dual Color Foot Well/ Overhead / Cup Holder/ Door Handle Pull Lighting / Rear Hatch Additional Lighting
  #13 (permalink)
Old 10-07-2010, 02:12 PM
MUSHVROOM3's Avatar
yeah, same here.
  #14 (permalink)
Old 10-09-2010, 08:26 AM
warlord's Avatar
warlord warlord is online now
M3R Moderator
Points: 30,188, Level: 100
Points: 30,188, Level: 100 Points: 30,188, Level: 100 Points: 30,188, Level: 100
Originally Posted by FullyFamous View Post
I'm having trouble locating the headlight adjustment screws on my 2010 Mazda 3 s Sport (regular projector beams, not HID). Dealership says they're not adjustable. Can't belive that.
I also want to adjust the factory foglights.
Pic on the left is the 8mm headlight aiming screw. Facing forward turn it clockwise for aiming them down. Pic on the right is the foglight. 10mm/phillips up/down adjustment screw is the black one on the lower left.
2013 BLACK MS3 w/TECH PKG
COBB AP stage1 272/305
AEM DRYFLOW DROP IN
H&R COILOVERS
TRIPOINT RSB
235/40 BFG COMP-2
The Following 2 Users Say Thank You to warlord For This Useful Post:
mirthenary (02-24-2012), Pomposso (04-14-2011)
  #15 (permalink)
Old 04-14-2011, 06:16 PM
mic-mic's Avatar
mic-mic mic-mic is offline
Points: 1,477, Level: 21
Points: 1,477, Level: 21 Points: 1,477, Level: 21 Points: 1,477, Level: 21
mic-mic is on a distinguished road
i think the best is to swap the lens to clear one and adjust the cut off inside the projector base. i think the adjustment work mostly for reflector based headlight.
| 2011 Mazda 3 i Touring | 2.0L Engine |
| Simota Intake | Morimoto 5FIVE 50w kit w/ 8000K | Clifford 50.7x w/ Remote Start | 31% Window Tint | LED Interior Light |
| DRL Side Glow LED w/ automatic on/off switch |
| Redline Tuning Hood Lift | Rear Lip Spoiler | WeatherTech Package Floor Liner |
  #16 (permalink)
Old 03-24-2013, 08:48 PM
joeywallstreet joeywallstreet is offline
Points: 470, Level: 9
Points: 470, Level: 9 Points: 470, Level: 9 Points: 470, Level: 9
Activity: 6%
joeywallstreet is on a distinguished road
sorry guys, im a noob. Is there any way to adjust the left/right of the headlights? I just replaced the factory lights on my 2011 with hids and have a solid black hole in front of me while driving. The sides of the road are lit up well, just not right in front. any help would be much appreciated.
  #17 (permalink)
Old 03-24-2013, 08:50 PM
mazda3UR's Avatar
mazda3UR mazda3UR is offline
DIY PRO
Points: 3,444, Level: 36
Points: 3,444, Level: 36 Points: 3,444, Level: 36 Points: 3,444, Level: 36
Activity: 88%
Activity: 88% Activity: 88% Activity: 88%
mazda3UR has a spectacular aura aboutmazda3UR has a spectacular aura aboutmazda3UR has a spectacular aura about
take out the plug and play kit and put in the halogen bulbs...
No there is no left or right adjustment on the headlights. Have you tried twisting the bulbs ever so slightly to see if you can refocus the light?
[facebook]
[garage]
  #18 (permalink)
Old 03-24-2013, 08:53 PM
Activity: 6%
thanks, i think. how would you recommend upgrading the headlights then? there isn't much play in terms of twisting the headlights.
  #19 (permalink)
Old 03-24-2013, 09:18 PM
mazda3UR's Avatar
DIY PRO
Activity: 88%
re read my post. I said twist the bulb...
By twisting the bulb it rotates the ignition portion of the hid bulb and can some times help with what you are running in to.
[facebook]
[garage]
  #20 (permalink)
Old 03-24-2013, 09:27 PM
Activity: 6%
so you're saying to twist the actual glass bulp within its plastic "foundation"?
aiming, headlight
