Hatch wing rattling - 2010-13 Mazda 3/Mazdaspeed 3 Forums
Go Back   2010-13 Mazda 3/Mazdaspeed 3 Forums > 2010-2012 Mazda 3 News & Discussion > 2010-12 Mazda 3 Discussion
Old 01-11-2012, 09:18 PM
dunston's Avatar
dunston dunston is offline
The One and Only
Points: 17,895, Level: 85
Points: 17,895, Level: 85 Points: 17,895, Level: 85 Points: 17,895, Level: 85
Activity: 62%
Activity: 62% Activity: 62% Activity: 62%
dunston is a splendid one to beholddunston is a splendid one to beholddunston is a splendid one to beholddunston is a splendid one to beholddunston is a splendid one to beholddunston is a splendid one to behold
Default Hatch wing rattling
I have had my car for about two years and always close the hatch gently. The past few weeks I started hearing a clunk when I closed it. Turned out the wing is loose. Has anyone else had the wing on their hatch loosen up?
M3R Moderator - PM me with any questions.
PARTS FOR SALE! ~~~> http://mazda3revolution.com/forums/m...eadlights.html<~~~
Old 01-12-2012, 08:41 AM
Desertnate Desertnate is offline
Points: 4,783, Level: 44
Points: 4,783, Level: 44 Points: 4,783, Level: 44 Points: 4,783, Level: 44
Desertnate will become famous soon enough
My spoiler moves a little bit, but not enough to make a clunk. It has around 1/4 of play in it. I'll probably get it fixed before the warranty runs out, but it hasn't been a big enough issue yet to miss hours at work to take to the dealer.
Graphite Metallic 2010 Mazda3 S 5-Door, 6-speed manual transmission
Auto-dimming mirror w/ compass and Homelink
Old 01-12-2012, 10:38 AM
carlos's Avatar
carlos carlos is offline
So Far So Good
Points: 2,787, Level: 32
Points: 2,787, Level: 32 Points: 2,787, Level: 32 Points: 2,787, Level: 32
carlos is on a distinguished road
Yes I had to take it to the dealer to fix it, waranty covered.
Mazda 3 HB GT 6MT - Celestal Blue - Sunroof
CS SRI - CS MM Inserts - Advanced Timing - TB Ground - 35/15 Tint - 55W 4200K Fog Lights - Black Painted Calipers - TWM Shifter Base Bushings - Tuned 4" Exhaust Tips - Resonator Delete - 1.25" RM Springs - SPC Rear Camber Arms - 3" Carbon Fiber Stub Antenna - Aluminum Pedals - LED DRLs, Interior & License Plate - Hankook Ventus V4 ES H105 225/45/17
Old 01-12-2012, 12:31 PM
Pennywise Pennywise is offline
Points: 3,707, Level: 38
Points: 3,707, Level: 38 Points: 3,707, Level: 38 Points: 3,707, Level: 38
Pennywise will become famous soon enough
Send a message via Yahoo to Pennywise
There are four nuts that hold it on. Open the hatch on the top of the hatch are two round plastic inserts that need to be popped out with a small screw driver and a pair of needle nose. The other two bolts are covered by the plastic interior piece that runs along the top of the window. Unclip that piece and you'll be able to see the bolts. I'm pretty sure about this, although this is from memory.
It wouldn't hurt to put thread lock on the nuts before tightening. However, be very careful not to drop the nut between the both panels. And, most importantly, do not crank them down too tight, just snug it up.
The Following 2 Users Say Thank You to Pennywise For This Useful Post:
Desertnate (01-12-2012), Laughing_Man (04-16-2013)
Old 01-12-2012, 03:54 PM
thebutlerdunnit thebutlerdunnit is offline
Points: 1,761, Level: 24
Points: 1,761, Level: 24 Points: 1,761, Level: 24 Points: 1,761, Level: 24
thebutlerdunnit is on a distinguished road
Are you sure it's the spoiler? I just had my latch replaced. It was making a lot of noise.
Old 01-12-2012, 05:35 PM
dunston's Avatar
The One and Only
Activity: 62%
yea, its the spoiler. It wiggles around a lot. I'll tighten it down today.
Old 01-12-2012, 06:01 PM
When I heard the noise, I was able to identify it as the spoiler. When I went to tighten the nuts up, the passenger side was almost completely off altogether. I guess they are not tightened down too much at the factory and the vibration caused it to loosen up completely. I guess mine was attached on the Friday afternoon shift...
Old 01-12-2012, 07:57 PM
stajlalexboy's Avatar
stajlalexboy stajlalexboy is offline
Points: 4,027, Level: 40
Points: 4,027, Level: 40 Points: 4,027, Level: 40 Points: 4,027, Level: 40
stajlalexboy is on a distinguished road
I've had mine tightened twice now, it starts to squeak going down the road at a very high pitch, and clunk when you close it Warranty covers it though...
Old 01-13-2012, 04:31 PM
Here are the torque specs for the hatch spoiler.
The Following User Says Thank You to Pennywise For This Useful Post:
dunston (01-17-2012)
Old 01-17-2012, 12:25 PM
SMOKIE780's Avatar
SMOKIE780 SMOKIE780 is offline
Points: 854, Level: 15
Points: 854, Level: 15 Points: 854, Level: 15 Points: 854, Level: 15
SMOKIE780 is on a distinguished road
Any time there is a change in road conditions, not matter if its a small pot hole i couldnt avoid or slightly uneven pavement. I hear a clunk or rattle from the hatch. I orginally thought it was my tools in the back. once i removed the tools i still hear the the noise and i am unsure of what it is. how can i tell what is causing this? i bought my car the first of september 2011 2.5l hatch. thanks for your help.
close, hatch, loose, rattling, wing
