Do my eyes deceive me ?? No after market clutches? - 2010-13 Mazda 3/Mazdaspeed 3 Forums
Go Back   2010-13 Mazda 3/Mazdaspeed 3 Forums > 2010-2012 Mazda 3 News & Discussion > 2010-12 Mazda 3 Engine and Performance
Old 10-11-2011, 08:51 PM
adubrocq adubrocq is offline
Points: 1,930, Level: 26
Points: 1,930, Level: 26 Points: 1,930, Level: 26 Points: 1,930, Level: 26
adubrocq is on a distinguished road
Default Do my eyes deceive me ?? No after market clutches?
Cmon guys help me out here. I have a 2011 Mazda 3s I have yet to find a single site that sells an aftermarket clutch for our model cars but yet i find tons for the"i" models and the MS3. Dude i find that very hard to believe!!
Please tell me it aint so!
Old 10-11-2011, 10:43 PM
stajlalexboy's Avatar
stajlalexboy stajlalexboy is offline
Points: 4,027, Level: 40
Points: 4,027, Level: 40 Points: 4,027, Level: 40 Points: 4,027, Level: 40
stajlalexboy is on a distinguished road
Unfortunately it is so! I have already gone through 2 clutches in my piece of crap! Its gonna cost you a nice $1586.xx for it to be replaced ! And no, the MS3 clutch and flywheel does not fit our cars... I have already asked!
Old 10-11-2011, 11:06 PM
jackf's Avatar
jackf jackf is offline
Smells of Elderberries
Points: 9,842, Level: 66
Points: 9,842, Level: 66 Points: 9,842, Level: 66 Points: 9,842, Level: 66
Activity: 12%
jackf is a glorious beacon of lightjackf is a glorious beacon of lightjackf is a glorious beacon of lightjackf is a glorious beacon of lightjackf is a glorious beacon of light
I've talked to ACT,Clutch Masters, Exedy...ect. Not one of them had any info on whether they will ever make one for the 2010+. That was over a year ago so you may want to check with them directly.
I plan on replacing my clutch and flywheel with a 04-09.... It's not 100% confirmed that it will work but its off to a good start... and should work in the reverse situation. Here is is what I have found out from a guy swaping the 2.5L engine into his 04' MZ3.
'04 2.3L to '10 2.5L Swap
author=jackf
Great Info!!! If you could... would you verify that the clutch cover for the 04+ will bolt up to the 2010+ flywheel....
author=mas04g l
Ok here goes: Since the engine is already in the car and I drove it around my block, I can verify that my '04 clutch stuff works without any adjustment. I used the '10 flywheel (same diameter as mine) and bolted my exedy clutch (OEM style replacement) to it. The dowels on the flywheel matched the cover just fine and I used all of my bolts. The transmission was left in the car for the swap (PITA) and bolted up to the 2.5L engine perfectly. All the engine to transmission bolts and bolt holes were utilized, and none of the motor/transmission mounts had to be moved..........
[/QUOTE]
// DPtune ECU Flash // Magnaflow Exhaust // Takeda CAI // 17x7.5 RPF1's // TWM Big TypeR Shift Knob // TWM Full Replacement Short Shifter // SRPracing pedals // GT LED Tail Lights // Redline Tuning Hood QuickLIFT // MS3 front brakes // MZ5 rear brakes // MSDS Header//Sure Motorsports rear mount // Massive Speed BSD // coming soon Cosworth MZ1 Cams
The Following User Says Thank You to jackf For This Useful Post:
adubrocq (10-26-2011)
Old 10-12-2011, 01:02 AM
noodles's Avatar
noodles noodles is offline
Parts test dummy
Points: 5,879, Level: 49
Points: 5,879, Level: 49 Points: 5,879, Level: 49 Points: 5,879, Level: 49
noodles has a spectacular aura aboutnoodles has a spectacular aura aboutnoodles has a spectacular aura about
I have been bugging these clutch manufactures as well but no dice. There is A flywheel available but it has yet to see it first production run because nobody wants to buy a flywheel without doing the clutch at the same time.
Mods to date: JDM Tein H-tech Springs (test) ~ CS RMM Insert ~ DDM 12000k HID Fog Lights ~ Switchback Signal Bulbs ~UV Nagare Accent Lights ~ FI Ground Kit (test) ~ CS Tow Plate ~ Tint: 15%R, 30%F, Air blue on WS ~ CWP Fog Bezels ~ CS 60mm exhaust ~ Redline Hood Lift Kit ~MSDS Header (test) ~ CS LED Interior Lights ~ Megan Racing STB (test) ~ Fujita SRI (test) ~ Kosei K1 TS 17x8 ~ VTCS Delete ~ N9th Racing Trunk Bar ~ AautoEXE front lower tie brace ~ RW Delete ~ Sure TVS caps
HAHAHAHAHA told you nothing was going to happen
Old 10-12-2011, 01:12 AM
Crespo's Avatar
Crespo Crespo is online now
College Zoom-Zoom
Points: 10,446, Level: 67
Points: 10,446, Level: 67 Points: 10,446, Level: 67 Points: 10,446, Level: 67
Crespo is a glorious beacon of lightCrespo is a glorious beacon of lightCrespo is a glorious beacon of lightCrespo is a glorious beacon of lightCrespo is a glorious beacon of lightCrespo is a glorious beacon of light
I read that thread a while ago and was going to reference it as well. Good info. Did you find out what parts were forged?
^^^My build thread^^^
Click the picture, you know you wanna...
>>>Mod of the Month<<<
Have something you want to sell on the forum? Abide by the rules.
http://mazda3revolution.com/forums/b...e-posting.html
Old 10-12-2011, 07:46 AM
spwalker09's Avatar
spwalker09 spwalker09 is offline
Points: 3,090, Level: 34
Points: 3,090, Level: 34 Points: 3,090, Level: 34 Points: 3,090, Level: 34
Activity: 22%
Activity: 22% Activity: 22% Activity: 22%
spwalker09 will become famous soon enough
Makes sense the 2.3 clutch would bolt up to the 2.5...the 2.5 is just a bored/stroked 2.3
The 2.0 has been around since the Protege days (its been updated internally, but externally its similar) so you figure they had to get around to it eventually
And we all know why there are aftermarket clutches for MS3s...
1994 Mazda MX-5 Miata
(Sold) 2010 Mazda3 i Touring: Graphite, 5 speed
Yakima rack | Volt 4300k 35w HID | Conti snows |
Dual-tone horn | Curt Class I hitch | Llumar CTX 30 tints
Old 10-12-2011, 03:00 PM
noodles's Avatar
Parts test dummy
We just need to get some people with the 2.5 to get the power up there enough to warrant an upgraded clutch.
Old 10-12-2011, 06:21 PM
Havocforming's Avatar
Havocforming Havocforming is offline
Points: 3,573, Level: 37
Points: 3,573, Level: 37 Points: 3,573, Level: 37 Points: 3,573, Level: 37
Activity: 58%
Activity: 58% Activity: 58% Activity: 58%
Havocforming will become famous soon enoughHavocforming will become famous soon enough
This I what I'm waiting on for a lot of performance parts. I'm rather disappointed that just because I couldn't afford the speed model I can't do much as far as mods go. I guess I'll just have to wait and see
Mods: all silver and chrome painted blue metal flake and blue chrome respectively. headlight housing done in blue chrome, blue metal flake mirror caps, painted front lip blue. Pioneer AVH-P8400BH head unit. Pioneer TS-W259S4 10" subwoofer. volfenhag 1200W amp (will upgrade soon). blue footwell lighting for front and rear seats. TRS 35W HID's 5000K Morimoto Elite. Graphite painted rims w/ blue evil m.
Old 10-12-2011, 07:40 PM
jackf's Avatar
Activity: 12%
Not yet... but I just bought as BSD plate so next oil change I will drop the pan and take a look and see while I'm down there taking off the balance shaft assembly.
Old 10-12-2011, 07:44 PM
I asked to see if the MS3 clutch and flywheel would fit our cars when mine was in the shop last week, and it does not
clutches, deceive, eyes, market
