2. That's exactly what happened to me! I was leaving work, had a green light, going straight and this lady on the opposite side pulls out and turns left right as I'm coming. I also was not at fault because I had right of way. My airbag did not go off, probably because most of the damage was to the front left side quarter panel. 3. Ouch! Chubbs and others have recommended TRS because they are more reliable than the DDM ones. Many users on this forum went with DDM and the ballasts ended up failing after awhile. It's entirely up to you if you want to go with DDM. I went with TRS when they had their sale going on.
__________________ 2012 Mazda 3 i GT Hatch w/ tech package - Sky Blue Mods: WeatherTech Floor Mats | OEM Fog Lights | TRS Morimoto Elite 3Five 4300K Fogs | OEM Zoom Zoom License Plate Frame | OEM Sunshade | 35% Front / 20% Rear Tint | CorkSport LED Kit | OEM LED Tail Lights | Turn Signal Side Mirrors | ||||||||||||||||||
I saw that you used a relay harness for your fogs, I'm planning on getting 3000k fog lights from DDMTuning, would I need to get a relay harness on it? I had 10000k headlights but I didn't need it, just double checking.
Sent from my Galaxy Nexus using AutoGuide.Com Free App | ||||||||||||||||||
typically 35watt ballast don't require relay harness but it is a good idea to run them to protect the stock wiring. DO NOT RUN 55WATT ballasts off the stock wiring...
| Yeah I read it wasn't needed for the 35w ballasts, but like Chubbs, I would rather use it and be safe than sorry haha.
Whats the worse that can do for your car? mess up the battery? I'm probably gonna order mine off iJDMToy just cause it's cheaper. Can someone verify the options for me? HID Conversion Kit | Xenon HID Kit | HID Headlights | HID Fog Lights What is "Error Free CAN-bus decoders" used for? Do I even need it? and yeah I'm probably gonna get the relay harness just to be safe If anyone on here wants to buy from there theres a 10% off code for it , code is "GoJDM"BulbType H11, 3000K (Yellow) and Relay harness. <-- everything should be fine? | ||||||||||||||||||
You do not need a can-bus error decoder thinger. Just a regular harness. And I'll say this just cuz I had a bad experience with a cheap hid kit. You get what you pay for. Sent from my Galaxy Nexus using AutoGuide.Com Free App | ||||||||||||||||||
| The Following User Says Thank You to HJLee For This Useful Post: | ||
Zilchary (05-15-2012) | ||
I agree. I would avoid iJDMToy. Their products are junk and they are dishonest. I bought a DRL controller from them and it didn't work. I placed a negative review and they deleted the review from their website.
| bulbs, fog, hid, howto, install, lights, oem |
