For those who don't know, the rear sway bar (RSB) provides resistance when one wheel tries to move independant of the other. This provides better handling when cornering, reducing body roll. It also has a noticable impact on understeer (the tendency for the car to turn a little less than you tell it to). No one has released a RSB for the 2010's yet, but I had someone check with Tri-Point Engineering and they said the aftermarket one they make for the 1st gen (04-09) bolted right up. So, I decided to take a chance and try a used Racing Beat RSB I was able to purchase on a forum. This was the first time I had ever worked on a RSB and I didn't have any instructions. Fun times! Lol. The install really wasn't bad at all. Honestly, I think it was easier than the horn upgrade. It did take a little longer, but some of that was me figuring things out. Total time was about 2 hours. Results: Understeer is noticably lower and the car is flatter in the corners. It just feels more planted. Uneven roads aren't an issue and the ride isn't much harsher than stock, if at all. I am satisfied at this point, but we'll see how it holds up over time. I can not guarantee anything, so use at your own risk! So, here's what we're looking at. The stock RSB is a little over 21mm. ![]() The Racing Beat RSB is right at 27mm, a significant difference of 6mm over stock. ![]() Here are all of the parts involved. The Racing Beat RSB is at the top and the stock RSB is below it. At the bottom left and right are the end links. They are what tie the ends of the RSB to the suspension arms. The 9/16" nuts and bolts that hold everything together are in the middle. You'll notice that the mount points are further out on the 2010. This isn't a huge deal, as you can slide the bushings out. It barely fits though and you don't get to use the "stoppers". ![]() These are the tools and supplies needed to swap the RSB:
![]() I was racing to get this done before the sun went down, so I didn't get install pics, but this should be enough if someone wants to try it: RSB Removal
RSB Install
__________________ Car is sold, but I am happy to answer any questions about my 3. - My Build Thread Last edited by Derrick_B; 08-08-2009 at 03:39 PM. | ||||||||||||||||||
| The Following 5 Users Say Thank You to Derrick_B For This Useful Post: | ||
dimachka (01-04-2010), frzburn (08-15-2009), glennk (08-08-2009), josh (08-08-2009), ReD-DrAgOn (10-11-2009) | ||
Good work man! I think you're pretty ballsy to be the first to try a 1st gen part on the new 3. I have a few questions: How much did you pay for the rsb? What forum did you find it on? How many miles were on the rsb from the previous owner? | ||||||||||||||||||
You have questions, I have answers:
__________________ Car is sold, but I am happy to answer any questions about my 3. - My Build Thread Last edited by Derrick_B; 08-07-2009 at 11:35 PM. | ||||||||||||||||||
| The Following User Says Thank You to Derrick_B For This Useful Post: | ||
BSUBigMac (08-08-2009) | ||
| Not so far. That kind of thing usually happens with the bar is binding inside the bushing. I should be able to control that easily with the grease zerks and a grease gun. Plus, the grease I use is specially made to prevent binding.
__________________ Car is sold, but I am happy to answer any questions about my 3. - My Build Thread Last edited by Derrick_B; 08-08-2009 at 02:24 AM. | ||||||||||||||||||
This is a good thread. It should be stickied!
Thanks guys ![]() Btw, I noticed that I made a mistake. The nuts and bolts are 9/16", not 19mm. It's all corrected now. Sorry about that. I'll also get a pic of it installed sometime today.
__________________ Car is sold, but I am happy to answer any questions about my 3. - My Build Thread | ||||||||||||||||||
| 2010, documented, install, rsb |
