Headlight modification Guide - 2010-13 Mazda 3/Mazdaspeed 3 Forums
Go Back   2010-13 Mazda 3/Mazdaspeed 3 Forums > 2010-2012 Mazda 3 News & Discussion > 2010-12 Mazda 3 How-To Guides
Old 11-16-2009, 01:59 AM
McGuyver_3 McGuyver_3 is offline
Points: 2,703, Level: 31
Points: 2,703, Level: 31 Points: 2,703, Level: 31 Points: 2,703, Level: 31
McGuyver_3 is on a distinguished road
Send a message via MSN to McGuyver_3
Default Headlight modification Guide
Hello my fellow members here are some steps of how to modify your lights I am not completely finished just yet i had just enough time to do the passenger side. Fortunatly I have a spare set of headlights haha.
As yuou all know the headlights have to be opened to be able to play around. Unfortunatly these headlights did NOT fit in my oven so i had to do the tedious job with a heat gun.
Seing how the cutoff on the preojectors are so poorly focused i decided to revert my attention to this first. after dissasembly of the headlamp i rigged up my own little test stand
The cutoff before any modifications
I removed the 2 screws that hold down the projector and compared them to the previous generation projectors unfortunatly there was no easy swap in swap out option as the previous generation had a larger projector. So i started adjusting how far the projector sits away from the housing and with a few adjustments i came up with the perfect distance
With that distance I saw what i wanted a sharp cutoff
Now i had to find something to make a spacer out of. Points to remember
Must withstand high heat
Must have similar round shape
I came up with aftermarket HID bulb holder
Cut the ring in half
Use heat source and bend plastic in to shape you need
I used just one peice and ran a test fire and didnt like what i saw as it was still to blurry so I added on the second peice that i had originally cut off
Once test fired again i saw whati liked
Next i moved on to painting the insides of the headlamps complete dissasembly and taped off the parts i wantred to stay original colour and installed the angey eye ring
I appologize for the vagueness of my instructions and details but please feel free to ask questions. When i do the drivers headlamp I will be more descriptive and take more pictures
Fortunatly I have a spare set of headlights i am tampering with
Short ram(cosmo racing), strut tower bar(gt spec), lowering springs Stech and sportlines mixed front and rear), camber arms(eibach), sway bars(F+R hotchkiss), tints, double din unit with wheel controls and backup camera, blacked out 3rd brake light and reflectors, side mirror glass with built in led turn signals convex mirror and blue tint, Horn upgrade, 6K fogs, 6k d2s Bulbs, RX8 wheels
The Following 2 Users Say Thank You to McGuyver_3 For This Useful Post:
ingram1225 (03-29-2010), jpn (03-29-2010)
Old 12-08-2009, 04:35 AM
darkknight49 darkknight49 is offline
Points: 177, Level: 3
Points: 177, Level: 3 Points: 177, Level: 3 Points: 177, Level: 3
Activity: 47%
Activity: 47% Activity: 47% Activity: 47%
darkknight49 is on a distinguished road
these arent HID lamps correct? Im wondering how the angel eye would work with the self leveling bi-xenons.
Future Mazda 3 Owner
Current Ride: 2008 Ninja 250r Black
Old 12-08-2009, 08:51 AM
AxelaSpeed's Avatar
AxelaSpeed AxelaSpeed is offline
Mazda3Revolution Glitch Finder
Points: 13,908, Level: 76
Points: 13,908, Level: 76 Points: 13,908, Level: 76 Points: 13,908, Level: 76
AxelaSpeed is on a distinguished road
Send a message via AIM to AxelaSpeed Send a message via Yahoo to AxelaSpeed
that looks awesome! great job on the work, let me know when u get a full description write up and then ill sticky the thread!
Old 12-08-2009, 06:57 PM
2010mazda3's Avatar
2010mazda3 2010mazda3 is offline
zoom zoom
Points: 7,277, Level: 56
Points: 7,277, Level: 56 Points: 7,277, Level: 56 Points: 7,277, Level: 56
2010mazda3 will become famous soon enough
yea i like the way u painted the lights. cant wait for more pics
Old 12-11-2009, 05:30 PM
Hey guys i appologize i have been so busy with school i have had no time for the boards. The headlamps are indeed oem xenon self levelling lights. The angel eye does not get intruded by the swivel as the housing is a fixed peic e and the projector moves on a seperate slider pin inside the headlamp housing. Unfortunatly 1 of my angel eye rings burnt out or died or whatever happened to it so i am awaiting its replacement and when that happens i will get more instructions up and possibly even change some more things around.
Old 01-04-2010, 01:37 AM
E150GT E150GT is offline
I'm a chicken
Points: 2,295, Level: 28
Points: 2,295, Level: 28 Points: 2,295, Level: 28 Points: 2,295, Level: 28
E150GT is on a distinguished road
What is the benefit of modifying the cutoff? Does it help you see better?
2010 Mazda3i sport- 26xx - Liquid silver sedan
Past Vehicles: 1986 Mercedes-Benz 420SEL, 2000 Ford Focus SE, 1982 Mercedes-Benz 300SD, 1988 Ford Crown Victoria, 1990 Ford Econoline 150
Old 01-23-2010, 12:28 AM
DarkSpeed3's Avatar
DarkSpeed3 DarkSpeed3 is offline
F*ck a sunroof.
Points: 7,147, Level: 55
Points: 7,147, Level: 55 Points: 7,147, Level: 55 Points: 7,147, Level: 55
DarkSpeed3 is just really niceDarkSpeed3 is just really niceDarkSpeed3 is just really niceDarkSpeed3 is just really niceDarkSpeed3 is just really nice
Nice work, Looks great. Check mine out
//DarkSpeed3
2010 Mazdaspeed3
- Drag DR-31 Gunmetal 18x8 +48
- Nitto NT 555 235/40/18
- H&R Springs
- Custom Headlights (pics) (video)
- Tinted Windows
- Xentec 10,000K HID
- DecalFX Yellow Fog Light Film (pic)
- DecalFX Smoked Tail Light Film (pic)
- CorkSport Intake
- Spoiler Swap
- Black Emblems
- DecalFX Matte Black Wrapped Fog Light Trim
- DecalFX Matte Black Dash Wrap (how-to video)
- DO NOT BUY A TWM SHORT SHIFTER!
- Also check out my blacked out 2009 RX-8 R3
The Following User Says Thank You to DarkSpeed3 For This Useful Post:
j3mmr71 (03-05-2011)
Old 03-29-2010, 12:00 AM
fraustij28 fraustij28 is offline
Points: 1,045, Level: 17
Points: 1,045, Level: 17 Points: 1,045, Level: 17 Points: 1,045, Level: 17
fraustij28 is on a distinguished road
i have put in HID lights and i notice tha tthe focus of the projector on the driver side is completely off, comparing to the passenger side. is there a way to fix the focus myself or I would have to go to the delasrship?
Old 03-29-2010, 12:34 AM
jpn's Avatar
jpn jpn is offline
Points: 3,260, Level: 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
jpn is on a distinguished road
Send a message via AIM to jpn
Where did you get the angel eye rings from? I've been searching...
EDIT: excited to see more pics of how to completely dismantle the inside parts of the light... I'm thinking of making custom eye brows and angel eye rings using the mini-blind rod and LED method.
think you could provide a diameter / radius / circumference measurement to use for making the angel eye rings?
Awesome job! I cannot wait to do mine!!!
EDIT: did you use any kind of special high-temp paint for painting insides of the headlights? think that's necessary? I want to use the same Metallic Black Night paint that I've used on the badges, but I may also consider using the same Graphite Mica body paint, neither of which are high-temp
2010 Mazda3 GT HB - Graphite Mica
Current: 50/35 tint | Horn Upgrade | Blackout badges/fog bezels | LED Parkings | HID Fogs | Blue Footwell Lighting Upgrade | JB Shift Bushings | CS SRI | CS strut bar | Blue/Red Air Vent Glow | VG Sharkfin | Custom Headlights w/Angel Eyes | Stealth Turns | LED Backups | DDM Tuning Pedals | LED 3rd Brake Light | Mazda Roof Rack | Yakima SkyBox
Planned: Painted Calipers | Short Shift | Smoked Tails | Carputer | Python Remote Start | FSB | RSB
Old 03-30-2010, 04:16 PM
jpn's Avatar
jpn jpn is offline
anyone know if the adaptive headlights move (when turning) even when they're not on...? that'll be a sweet effect... like eyes looking where they're going...
guide, headlight, modification
