@ 37,500 miles and starting to hear pop noise - Page 3 - 2010-13 Mazda 3/Mazdaspeed 3 Forums
  #21 (permalink)
Old 02-28-2012, 10:22 PM
fc3schick87's Avatar
fc3schick87 fc3schick87 is offline
girls can too
Points: 5,638, Level: 48
Points: 5,638, Level: 48 Points: 5,638, Level: 48 Points: 5,638, Level: 48
fc3schick87 will become famous soon enough
Send a message via AIM to fc3schick87
update
it may be my spoiler making this clunk noise. yes it sounds almost identical to the 1st gen mazdaspeed clunk but.... i had my car at mazda today and they inspected it durring my oil change and transmission fluid flush and found no sign of wear on mounts or struts.
i read elsewhere that the 2nd gen mazdaspeed spoiler makes a clunking noise due to the foam stripping not being thick enough. this foam strip goes between the spoiler and the chassis. it was installed on my freashly painted mazdaspeed spoiler that i installed about 2 months ago, i have seemingly been hearing this noise since.
i'll keep this thread up to date , especially since i am installing RB springs soon with eibach camber adjustment kit
mz3 2010,
MS3 2012,
mz 2 2012,
rx7 1987,rx7 1987 (both tii)
(yeah that many mazdas!)
  #22 (permalink)
Old 03-07-2012, 07:17 PM
amati5 amati5 is offline
Points: 2,360, Level: 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
amati5 is on a distinguished road
I am reading this thread because my 3 is making the sound in the rear too. Not sure if it's "pop" but it's more like "thud" over bigger bumps. I thought it was the grease dried up in the sway bar bushings but regreasing them didn't get rid of the sound. The stock endlinks look solid and I hope it's not blown shocks (stock with Prokit). I mostly drive by myself and only have 6 kmiles on it. The cars has no spoiler.
  #23 (permalink)
Old 03-07-2012, 11:22 PM
girls can too
Check your tano cover, check your spare tire, check the foam cover that goes over the spare tire. Place a blanket ontop of the spare tire, remove tano cover that covers the hatch.
How much of a drop is the pro-kit?
A tud is normal but popping and clunking is not, with normal driving. What seires tire do you have. Did you recently decrease the size? 50 series ride more quiet then 45 series. Also, stock tires suck, the ride was loud when I had my stock yokohama on after about 7,000 miles. I swapped them out for more soft side wall tires.
The suspention makes a distinct pop, not to be confused with other noises. You are under warrenty. I suggest putting your stock rear springs back on and take it into mazda!
mz3 2010,
MS3 2012,
mz 2 2012,
  #24 (permalink)
Old 03-08-2012, 11:06 AM
Found the problem last nite, it's the left endlink. It was just a little loose and I couldn't believe it made such loud noise. When I was regreasing the bushings, I checked the endlinks and they seemed to be tight, couldn't tell by just feeling it until last night I used the wrench to check and the nut was not tight.
  #25 (permalink)
Old 03-08-2012, 10:56 PM
girls can too
so your sound went away for sure?
sweet..... imo i am sure my dealership inspects these end links and such. my car doesnt make as much noise since i went in for an oil change at my fav high tech dealership "north park mazda" which is in the top 25 dealerships in usa ^_^
mz3 2010,
MS3 2012,
mz 2 2012,
  #26 (permalink)
Old 03-09-2012, 11:05 AM
Solid like a rock. I was sure when I started upgrading suspension parts that I would be on my own when things go wrong. Dealers aren't going even to check when they see after market parts. I used electrical tape to cover the "Eibach", just in case anyway.
  #27 (permalink)
Old 03-23-2012, 10:37 AM
vwsb74 vwsb74 is offline
Points: 1,965, Level: 26
Points: 1,965, Level: 26 Points: 1,965, Level: 26 Points: 1,965, Level: 26
vwsb74 is on a distinguished road
mine was like that too after installing rm. the shop could not find the problem but I did. It was the endlink on the rear away bar. Just tighten them up and you will be fine.
  #28 (permalink)
Old 03-23-2012, 12:10 PM
girls can too
yeah i no longer have the noise that i usto. but our end links were not loss. the end links are odd they are joints. good thing they are easy to get to and replace!
mz3 2010,
MS3 2012,
mz 2 2012,
500, hear, miles, noise, pop, starting
