I cannot figure out how to put the rear coilovers in and no matter where I look I can't find any pictures of them on a car either. Anyone have a picture or can help me otherwise? Sent from my Autoguide iPhone app
__________________ PM for Coilover installation! | ||||||||||||||||||
is it the strut you are having problems with or the springs? if its the strut remove the top bolts from inside the well holding the sock struct keep the bolts you will need them. also you will need to remove your camber arm in order to get the springs in as well.once you have the bc strut in and the springs just put everything back together and you should be good. hope this helps a bit if not I'll help you more with detail
__________________ AutoProject: Rebuild for the Rebirth | FurBallers | StreetUnit 2010 Black Mica Mazda 3s Sport 2.5L Hatchback 1987 Crystal White Pearl Mazda Rx-7 FC3S S5 | ||||||||||||||||||
Nah I'm fine with the strut, it's just the spring part... Where do I put the perch that allows you to adjust the height? The bottom or the top of the spring? Sent from my Autoguide iPhone app
Rubber, Perch, Plastic, Spring...make sure the bottom and end of spring stops in the hole...
__________________ R.I.P. 2011 Mazda Mazda3 s Grand Touring 4-Door Current Mods: Injen SRI/CAI (BLK)||RB RSB||RB FSB||Tri-Point RE's||CorkSport FE's||CorkSport Brakelines||Dunlop Direzza Sport Z1 Star Spec's (225/45/17))||Meng Motorsports 6000k HIDs||WT Mat's||CorkSport LED Conversion||BC Coil-Overs||SPC Chamber Arms|| Future: Matsu STB||Enkei Funjin's (17")||Stoptech Rotors||DP Tune||AT||CorkSport Exhaust||MSDS Headers|| R.I.P. 2011 Acura RDX SH-AWD Turbo Current Mods: Hondata Tune|| | ||||||||||||||||||
One end of the spring should be ground flat. That side goes against the perch.
__________________ 2013 BLACK MS3 w/TECH PKG COBB AP AEM DRYFLOW DROP IN H&R COILOVERS TRIPOINT RSB FORGED CAMBER ARMS MATT SILVER TSW NURBURGRING 18x8.5+45 235/40 BFG COMP-2 | ||||||||||||||||||
bringing this thread back from the dead.... do i need to take out my rear sway bar to adjust the rear height?? going lower tuesday and id just like to get a basic idea of what the hell i have to do before i just jack it up and start doing useless shit.
Well I can't get to the rings that adjust the height...lol Sent from my Autoguide iPhone app
| rear |
