Help with rear camber adjustment - 2010-13 Mazda 3/Mazdaspeed 3 Forums
Old 08-11-2012, 02:59 PM
JosephJ85's Avatar
JosephJ85 JosephJ85 is offline
Points: 972, Level: 16
Points: 972, Level: 16 Points: 972, Level: 16 Points: 972, Level: 16
JosephJ85 is on a distinguished road
Default Help with rear camber adjustment
Ok so i have a 2012 Skyactiv hatch and lowered it with RM 1.75 in the rear and Eibach Sportlines in the front to make up for the .5" difference due to the lighter engine (2.2 - .5 = 1.7" drop up front)... my problem is that i have serious rear camber in the back, i have the Eibach/SPC adjustable arms installed but when i took the car to get aligned the dude doing the work said he didn't see how he would be able to adjust the rear without taking the tires off and eyeballing it since the adjustment bolts are at a hard to reach space... has anyone had this problem or was the guy just being lazy and should i try a different alignment shop. Also if anyone is from NY specifically the Bronx or Yonkers area could you recommend a shop.
Or how hard would it be to remove the tire and "eyeball" the rear camber myself...
MODS: Plastidipped Emblems / Tints: 30%Front, 20%Back / Megan Racing Front Upper Strut Bar / Koni Orange Front and Rear / Springs: Front = Eibach Sportlines (2.2" - .5 = 1.70" drop) - Rear = Road Magnet 1.75" / Eibach Camber Kit / Corksport Rear Sway Bar
Old 08-16-2012, 01:57 AM
Steveo8x8's Avatar
Steveo8x8 Steveo8x8 is offline
Points: 2,474, Level: 30
Points: 2,474, Level: 30 Points: 2,474, Level: 30 Points: 2,474, Level: 30
Activity: 2%
Steveo8x8 is on a distinguished road
i had to do the same thing. i had them check it on the machine and tell me how far off it was from being aligned correctly then i went home and took the tires off then brought it out to where i thought it should be. i found 2 points of reference on the arms so i could have the same length on both sides. then i brought it back in to have it checked and it was all good
Old 08-16-2012, 11:39 AM
carlos's Avatar
carlos carlos is offline
So Far So Good
Points: 2,787, Level: 32
Points: 2,787, Level: 32 Points: 2,787, Level: 32 Points: 2,787, Level: 32
carlos is on a distinguished road
I have the same adjustable arms...yes they are quite hard to reach but not impossible. Mine was aligned twice without the need of removing the wheels. Take your car to another shop and don't let a lazzy fatty guy going under it...
Good luck!
Mazda 3 HB GT 6MT - Celestal Blue - Sunroof
CS SRI - CS MM Inserts - Advanced Timing - TB Ground - 35/15 Tint - 55W 4200K Fog Lights - Black Painted Calipers - TWM Shifter Base Bushings - Tuned 4" Exhaust Tips - Resonator Delete - 1.25" RM Springs - SPC Rear Camber Arms - 3" Carbon Fiber Stub Antenna - Aluminum Pedals - LED DRLs, Interior & License Plate - Hankook Ventus V4 ES H105 225/45/17
Old 09-10-2012, 10:49 PM
SHABBA6789's Avatar
SHABBA6789 SHABBA6789 is offline
General
Points: 2,074, Level: 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Activity: 1%
Activity: 1% Activity: 1% Activity: 1%
SHABBA6789 is on a distinguished road
Take it to another shop...it can be done with the tires on and a jack...it can be a pita so most basic shops will say they can't do it...
R.I.P. 2011 Mazda Mazda3 s Grand Touring 4-Door
Current Mods: Injen SRI/CAI (BLK)||RB RSB||RB FSB||Tri-Point RE's||CorkSport FE's||CorkSport Brakelines||Dunlop Direzza Sport Z1 Star Spec's (225/45/17))||Meng Motorsports 6000k HIDs||WT Mat's||CorkSport LED Conversion||BC Coil-Overs||SPC Chamber Arms||
Future: Matsu STB||Enkei Funjin's (17")||Stoptech Rotors||DP Tune||AT||CorkSport Exhaust||MSDS Headers||
R.I.P. 2011 Acura RDX SH-AWD Turbo
Current Mods: Hondata Tune||
Old 10-01-2012, 06:28 PM
amati5 amati5 is offline
Points: 2,360, Level: 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
amati5 is on a distinguished road
Tell your mechanic he needs a set stubby wrench. It still takes longer than normal but very possible.
adjustment, camber, rear
