Long Startup - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 1Likes
  • 1 Post By Fluffy6079
post #1 of 5 (permalink) Old 05-15-2016, 09:54 AM Thread Starter
Fluffy6079
Points: 1,176, Level: 18
Points: 1,176, Level: 18 Points: 1,176, Level: 18 Points: 1,176, Level: 18
Activity: 6%
Fluffy6079's Avatar
Long Startup
For the past few weeks I've had long startup times in my 2010 Mazdaspeed 3. I'll get in and push the button and it takes a lot longer to crank the engine that it should. It only seems to do it once the car has been sitting for several hours. If I drive, park somewhere for a while, then start it up to leave it fires right up. The obvious thing to me would be the fuel pressure regulator, but I've had a hard time finding any posts (here and elsewhere) where people have definitively resolved the issue and I don't want to go through all the trouble to pull the gas tank for nothing. Has anyone else experienced this problem and been able to fix it?
"I do what I can. Sometimes, I do what I can't."
Fluffy6079 is offline
post #2 of 5 (permalink) Old 05-20-2016, 12:59 PM Thread Starter
Fluffy6079
Activity: 6%
Fluffy6079's Avatar
Anyone? Has no one been able to figure out a fix for this?
post #3 of 5 (permalink) Old 07-04-2016, 11:19 AM Thread Starter
Fluffy6079
Activity: 6%
Fluffy6079's Avatar
I have been able to fix the issue. My car eventually started running a bit rough at idle in addition to the cranking issue. I took my EGR valve off and found the spring to be stuck. I used carburetor cleaner and thoroughly cleaned it, reinstalled it, and all my problems were solved.
btijet likes this.
post #4 of 5 (permalink) Old 09-12-2016, 12:16 PM
Fizboy
Points: 1,826, Level: 25
Points: 1,826, Level: 25 Points: 1,826, Level: 25 Points: 1,826, Level: 25
Same Issue
I have been having the same issue. I will try cleaning the EGR valve and see if I get the same result and report back.
Fizboy is offline
post #5 of 5 (permalink) Old 11-26-2016, 09:06 AM Thread Starter
Fluffy6079
Activity: 6%
Fluffy6079's Avatar
I'm curious to see if you were able to fix your issue as well. It's been a few months now and I still haven't had any more problems.
long , startup
