Please help me upgrade my 2010 MS3 - Page 15 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 1Likes
post #141 of 145 (permalink) Old 02-20-2015, 06:40 PM
mazdaspeedmyk
Turbo Zoom Zoom
Points: 55,390, Level: 100
Points: 55,390, Level: 100 Points: 55,390, Level: 100 Points: 55,390, Level: 100
mazdaspeedmyk's Avatar
Originally Posted by idamike View Post
hey guys how it going.. okay so i read as much as i can on there about going stage 1,2 3
right now all i have is the CS stage 2 SRI.
now should i go AP and internals before i do anything else? or can i do anything else before internals ?
Internals and an AP are a must at this point.
mazdaspeedmyk is offline
The Following User Says Thank You to mazdaspeedmyk For This Useful Post:
Redline_Tuner (07-17-2015)
post #142 of 145 (permalink) Old 02-20-2015, 06:58 PM
idamike
Points: 2,527, Level: 30
Points: 2,527, Level: 30 Points: 2,527, Level: 30 Points: 2,527, Level: 30
alright with internals will that cause me to not pass smog ? sorry if that a noob question
idamike is offline
post #143 of 145 (permalink) Old 02-20-2015, 07:16 PM
mazdaspeedmyk
Turbo Zoom Zoom
If you're worried about passing smog, you can stop modding now. You picked a good SRI, since the CS is CARB legal. The HPFP internals are mandatory for going "stage 2". Adding a Downpipe, TMIC/FMIC, and tuning for these parts will not allow you to pass smog.
post #144 of 145 (permalink) Old 02-20-2015, 09:31 PM
idamike
ohh okay.. well i was just wondering so i can keep the oem internsls for when i do need to smog i can swap them back in pass my smog then put my upgrades back on ...
okay so once i buy my internals and the ap then i can go for an upgraded tmic downpipe ?
i want to be able to boost around 20-22psi.. for that what would i need ?
idamike is offline
post #145 of 145 (permalink) Old 07-17-2015, 08:00 PM
Redline_Tuner
Points: 1,053, Level: 17
Points: 1,053, Level: 17 Points: 1,053, Level: 17 Points: 1,053, Level: 17
Activity: 80%
Activity: 80% Activity: 80% Activity: 80%
Redline_Tuner's Avatar
HPFP internals will have absolutely zero bearing on passing smog. Just install them and leave them. IMHO all Speeds should've come with better HPFP internals from the factory. When I first started self-tuning in 2012 I ran out of fuel at only ~18psi during the wintertime. 2010+ Speeds are much worse about this because of the ECU's fueling logic too... If you wanna boost to 20-22, you'll definitely need to upgrade to a performance TMIC or a FMIC. The stock TMIC is a real bottleneck. And I recommend being tuned for ~21 because your stock 2.5 BAR MAP sensor loses resolution above that point. If you really want that extra 1psi (going to 22psi), upgrade to a 3 BAR. Any reputable tuner will tell you all of this.
FREEK'D FTW! | 93 Octane: 325/340 | E28 Mix: 385/380
COBB AP | Autotechs | BNR S3 v1 | HTP 3.5" | JBR Piping & TR8C | Synapse DV | Full 3" Custom Exhaust | Stratified 3-Port & GA v2 | 3-Bar MAP
JBR Rear Sway Bar | Swift Springs/Koni Yellow Struts/Bilstein B8 Shocks | SPC Arms | Stoptech Lines | CS Pads
JBR 88d RMM/80d PMM, IM & TB TIGs, Coolant Bypass, SSP, Bushings, & Knob | MD OCC
245/40 - 17 Michelin PSS on MB Weapons | Rolled Fenders
Redline_Tuner is offline
2010 , corksport , ms3 , upgrade
