Amp/Sub install with factory radio and LOC - Page 2 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
post #11 of 28 (permalink) Old 10-16-2009, 04:58 PM
Derrick_B
Resident MacGyver
Points: 14,879, Level: 79
Points: 14,879, Level: 79 Points: 14,879, Level: 79 Points: 14,879, Level: 79
Derrick_B's Avatar
Well, the 4 gauge may limit my options. The install I saw on the passenger's side was 1/0 gauge, so that was really the only way to do it.
Car is sold, but I am happy to answer any questions about my 3. -
Derrick_B is offline
post #12 of 28 (permalink) Old 10-16-2009, 05:53 PM Thread Starter
JONtheBOMB
Points: 2,586, Level: 30
Points: 2,586, Level: 30 Points: 2,586, Level: 30 Points: 2,586, Level: 30
Originally Posted by Derrick_B View Post
I was referring to the big 3 wiring upgrade (alt to battery, battery to chassis, and engine ground to chassis).
This will ensure that everything is grounded properly. The OEM wire is just enough for what's in the stock car, so the big 3 is generally recommended whenever you do an upgrade to avoid things like dimming lights
Wow, I did not know this... I've been driving the car like this for a week now and never noticed the headlights dim or anything. I should note that my amp is really not that powerfull and I keep it turned down most of the time. I just like smooth undistored bass at low volumes (I think im getting old) The headlight dimming used to happen in the Z. Was running two amps turned up but nothing so far on the MS3.
Ill look into it and post a video later at night with the system blasting.
Thanks for the info!
JONtheBOMB is offline
post #13 of 28 (permalink) Old 10-16-2009, 06:11 PM
Homer3D
Points: 8,428, Level: 61
Points: 8,428, Level: 61 Points: 8,428, Level: 61 Points: 8,428, Level: 61
Homer3D's Avatar
The big 3 is not something that is really needed. It is one of those "just in case" sort of things. I have had so many cars with so many systems, and I personally have never done this. Not saying it doesn't have its value, but my lights never dimmed. Well it did on one of my cars, but that's because the battery was dying.
Homer3D is offline
post #14 of 28 (permalink) Old 10-16-2009, 09:33 PM
Derrick_B
Resident MacGyver
Derrick_B's Avatar
Yeah, it's a precautionary thing, just like so many things on cars. The upgrade is pretty easy and inexpensive. I'll be doing it once I have everything else in my system taken care of.
post #15 of 28 (permalink) Old 11-05-2009, 11:02 PM
ilandaze_808
Points: 2,278, Level: 28
Points: 2,278, Level: 28 Points: 2,278, Level: 28 Points: 2,278, Level: 28
ilandaze_808's Avatar
which two wires did u use to tap in on the deck wire harness for the high/low converter or loc
ilandaze_808 is offline
post #16 of 28 (permalink) Old 11-08-2009, 01:42 AM Thread Starter
JONtheBOMB
I edited the first post, heres the info:
There is a wiring diagram for the big plug behind the radio here: 2010 Mazda 3 Stereo upgrade
My_Mazda3 has a good write up there.
I spliced the front speaker wires labeled "1A, 1C, 1D, 1F" on the diagram or "FL+, FL-, FR+, FR-" respectively. My LOC also had a ground which I spliced aswell, its "1W"
post #17 of 28 (permalink) Old 02-22-2010, 08:14 PM
hatchetmazda3
psychopathic ryda
Points: 662, Level: 13
Points: 662, Level: 13 Points: 662, Level: 13 Points: 662, Level: 13
i finally am getting around to putting my system in. only problem i have run into is what fuse to use for the remote wire. i know the outlet fuses are in the passenger side fuse box but for the life of me i could not find it. (it was dark and i was very short tempered so didnt take much for me to give up for the night.) all the fuses in the engine box seem to have constant power and not acc/on power only. could someone help please. i am goin to tackle it tommorow
hatchetmazda3 is offline
post #18 of 28 (permalink) Old 02-22-2010, 08:29 PM
warlord
Points: 48,012, Level: 100
Points: 48,012, Level: 100 Points: 48,012, Level: 100 Points: 48,012, Level: 100
Seems like everybody taps into the cigarette lighter for the amps remote turn on wire. It's a switched circuit. If someone else has a better idea chime in.
2013 MS3 (sold) / 2011 MS3 (sold) / 2010 MZ3 (sold)
2014 Lexus IS350 Silver lining metallic/Nav Pkg (current daily driver)
I don't know the key to success, but the key to failure is trying to please everyone...
My newest vice.
Sending me to the poorhouse faster than any of my Mazdaspeeds ever did.
warlord is offline
post #19 of 28 (permalink) Old 03-31-2010, 12:50 PM
naz
Points: 5,481, Level: 47
Points: 5,481, Level: 47 Points: 5,481, Level: 47 Points: 5,481, Level: 47
Hey..
Thanks for the pics, just ran my power line today. There's also another firewall pass though on the drivers side, kind of behind the strut mount and battery. I used 8 awg, but you should be able to use 4 awg as long as you have not run anything else there yet. I had run the car alarm cables there already, so had to use the 8 awg.
cheers
naz is offline
post #20 of 28 (permalink) Old 05-26-2010, 11:44 PM
Pomposso
Points: 2,616, Level: 31
Points: 2,616, Level: 31 Points: 2,616, Level: 31 Points: 2,616, Level: 31
Pomposso's Avatar
I tapped into what i believe is the air bag sensors under the seats for the remote . It made it easy to add a rocker switch right under the seat (easy reach + hidden) so i can turn the subs when my gf gets a headache.
Pomposso is offline
amp , amp or sub , factory , install , loc , radio
