Just so I understand this all the dash lights were either on or flashing at you and you continued driving it for 5 mins? Year? Model? | ||||||||||||||||||
1. Your water pump and power steering stopped working the second the belt broke. It only takes less than a minute to overheat the engine once the water pump stops working. I'm guessing coolant boiled over on you. 2. Not sure. My car has 140K miles on the original belt. I inspect it every now and then and it still looks good. Last edited by Adam3s; 07-06-2012 at 01:47 PM. | ||||||||||||||||||
Lights were on, but the coolant wasn't boiling, neither feeling super hot nor coming out any smoke. Took it to the dealer and just the belt and the water pump were in trouble, car runs fine now. No idea what hell happened with the belt. 2011 speed3 Sent from my Autoguide iPhone app | ||||||||||||||||||
always a possibility of a warped head, maybe you dodge a bullet, maybe ... were you coasting for 5 minutes? Did the coolant light go red as soon as it snapped or after driving? cuz with todays cars, the coolant temp sensor reads hot at like 250+degrees.. which is warpage temps.. I would at least get a coolant flush, get some fresh stuff, change the oil, and take it easy and listen for weird noises. also if there is more pressure then normal in your coolant system it could be a blown head gasket / cracked head / cracked blockeven with no other signs ( coolant in oil, oil in coolant ) | |||||||||||||||||
glad it turned out well, could have been bad. suprisingly though i changed my belt at 50k and it was barely cracking. I actually kept mine just in case.
__________________ 2012 Camry SE - K&N 2012 Cruze LT2 RS -Custom intake courtesy of some corksport parts scangauge w/blend mount
| belt, broken, serpentine |
