ms3 possible defective Dunlop tires - Page 3 - 2010-13 Mazda 3/Mazdaspeed 3 Forums
Go Back   2010-13 Mazda 3/Mazdaspeed 3 Forums > 2010-2013 Mazdaspeed3/Mazda 3 MPS News & Discussion > 2010-13 Mazdaspeed 3 Wheels and Tires
  #21 (permalink)
Old 03-05-2012, 05:11 PM
warlord's Avatar
warlord warlord is offline
M3R Moderator
Points: 30,425, Level: 100
Points: 30,425, Level: 100 Points: 30,425, Level: 100 Points: 30,425, Level: 100
Originally Posted by badmoonkid View Post
I have stock 2010 ms3 and have the same tire wear I think it a mazda desing problem mazda need to fix I did not pay all that money to replace tires every 15 thousand miles !!
" its the strut rubbing on the tire"
http://i901.photobucket.com/albums/a...d/IMAG1402.jpg
That looks like a defective tire or possible under inflation. Your wear is even across the tread so it doesn't look like a factory alignment issue. With the amount of tread you have left at 15k it looks like your tires would have lasted at least 25k if the sidewall didn't separate like that. I'd try to get that tire warranteed.
2013 BLACK MS3 w/TECH PKG
COBB AP
AEM DRYFLOW DROP IN
H&R COILOVERS
TRIPOINT RSB
FORGED CAMBER ARMS
235/40 BFG COMP-2
  #22 (permalink)
Old 03-05-2012, 06:04 PM
warlord's Avatar
M3R Moderator
Stock MS3 comes with -1 neg camber in front. That's not really a lot of neg camber. It can't be the tire rubbing on the strut either if he's on stock wheels. There's a good 10-12mm of room between the tire and strut. Even under hard cornering the tire won't deflect enough to touch. IDK. I'm still thinking defective tire or under inflation. Dunlops or owners fault not Mazda's.
COBB AP
AEM DRYFLOW DROP IN
H&R COILOVERS
TRIPOINT RSB
FORGED CAMBER ARMS
235/40 BFG COMP-2
  #23 (permalink)
Old 03-05-2012, 08:28 PM
badmoonkid badmoonkid is offline
Points: 81, Level: 1
Points: 81, Level: 1 Points: 81, Level: 1 Points: 81, Level: 1
badmoonkid is on a distinguished road
its both sides not just one and yes I check the tires for air as well
  #24 (permalink)
Old 03-05-2012, 09:15 PM
warlord's Avatar
M3R Moderator
Why Tires Fail
COBB AP
AEM DRYFLOW DROP IN
H&R COILOVERS
TRIPOINT RSB
FORGED CAMBER ARMS
235/40 BFG COMP-2
  #25 (permalink)
Old 04-27-2012, 02:09 PM
ivan ivan is offline
Points: 2,059, Level: 27
Points: 2,059, Level: 27 Points: 2,059, Level: 27 Points: 2,059, Level: 27
ivan is on a distinguished road
Hell oeveryone, I am at 20K and the front tires lost the inner wall, as I thought it would happen, when the thread on the rest of the tire is still good. Taking to dealer to see answer.
Any chance that under acceleration the bushings/linkage may flex too much and cause the wheels to flare open?
  #26 (permalink)
Old 04-27-2012, 02:56 PM
warlord's Avatar
M3R Moderator
I'm at 16k and mine are doing it too. It's from toe in. Mazda in their infinite wisdom wants us to have high speed stability. This is the price we pay for it.
COBB AP
AEM DRYFLOW DROP IN
H&R COILOVERS
TRIPOINT RSB
FORGED CAMBER ARMS
235/40 BFG COMP-2
  #27 (permalink)
Old 04-28-2012, 10:37 AM
Hi Warlord, you mean toe out? Excuse my ignorance, but if it was too much toe in, wouldn't it be the wear on the outside shoulder?
  #28 (permalink)
Old 06-09-2012, 02:11 PM
Badguppy Badguppy is offline
Points: 72, Level: 1
Points: 72, Level: 1 Points: 72, Level: 1 Points: 72, Level: 1
Activity: 6%
Badguppy is on a distinguished road
Default Same problem.
Just hit 18k with same stock tires and both in the front look exactly the same as yours. Dealership told me the problem was the I needed 2 new tires.
  #29 (permalink)
Old 06-09-2012, 03:15 PM
LiquidM3SGT LiquidM3SGT is offline
Points: 1,888, Level: 25
Points: 1,888, Level: 25 Points: 1,888, Level: 25 Points: 1,888, Level: 25
Activity: 58%
Activity: 58% Activity: 58% Activity: 58%
LiquidM3SGT will become famous soon enough
It's a combination of the higher camber the car has, and the mild toe OUT that a front wheel drive car has. Then also a consequence of having a high performance tire that has lower tread depth (8-9/32nds). So mileage wear shows much faster on MS3 tires than standard MZ3s.
2012 2.5 S GT
Corksport SRI
Corksport STB
Mazda Remote Start
  #30 (permalink)
Old 06-11-2012, 12:54 AM
Master01 Master01 is offline
Points: 905, Level: 16
Points: 905, Level: 16 Points: 905, Level: 16 Points: 905, Level: 16
Master01 is on a distinguished road
Hi All,
I have a 2012 MS3 and with 2300 miles on it, I too am seeing the inside shoulder wear. I'm going to have my mechanic do an alignment check on it to see where its at.
I also have noticed that the Dunlops loose air faster than other tires I've had.
I'll post back when I get the alignment checked this week.
defective, dunlop, ms3, tires
