Cruise Control won't engage - Page 2 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
post #11 of 22 (permalink) Old 01-21-2016, 03:25 PM
dlaning
Points: 12, Level: 1
Points: 12, Level: 1 Points: 12, Level: 1 Points: 12, Level: 1
Same issue
I also have had this happen three times since the eve of Xmas day. The intermittent nature of the problem is truly aggravating! When I discuss with a Mazda service adviser they said unless it is reproducible it would be difficult to determine, obvious response. Was anyone else having this issue had more favorable results?
dlaning is offline
post #12 of 22 (permalink) Old 01-30-2016, 01:27 PM
wilber sonic
Points: 1,211, Level: 19
Points: 1,211, Level: 19 Points: 1,211, Level: 19 Points: 1,211, Level: 19
Per isteal original post .
I have a 2013 Mazda 3-5. 21000+ miles. Do lots of freeway driving. Have had the cruise control act just as described twice. All other times it arms (amber) and engages (green) as expected. When engaged, it works perfectly.
Will be off to the dealer for resolution soon.
wilber sonic is offline
post #13 of 22 (permalink) Old 01-31-2016, 02:29 PM
jegonzo3
Points: 3,256, Level: 35
Points: 3,256, Level: 35 Points: 3,256, Level: 35 Points: 3,256, Level: 35
Activity: 15%
I've had the same issue also, which started about 1 month ago, otherwise it's worked fine since I bought the car around 1 1/2 years ago.
As some of the other posters have said, turn off car, turn back on, it works again.
2013 Mazda3 i Grand Touring Skyactive Hatchback - Indigo Lights Mica
Mods so far: Rear view Mirror with Homelink/Compass | Plasti-dipped silver trim on passenger and driver side | Installed one-touch up/down for all 4 windows | Drag DR-33 17" Rims and Continental ControlContact Sport AS 235/45 R17 Tires | Pioneer AVH-4200NEX w/Navigation | Fog lights | LED Turn Signal Indicators on Side Mirrors | LED Hatch Lighting | Foot-well Lighting | Visual Garage Shark Fin
jegonzo3 is offline
post #14 of 22 (permalink) Old 02-04-2016, 08:05 AM
jcolvy
Thumbs down 2012 Mazda3 Cruise Control Works Sometimes
My 2012 Mazda3 cruise control works sometimes. Other times, it won't engage at all. Then I turn off the car at a stop light and then turn it back on and the cruise control seems to work. It is kind of like Microsoft - just reboot! This is not very convenient with a car. Does anyone of a resolution?
jcolvy is offline
post #15 of 22 (permalink) Old 02-19-2016, 12:04 PM
dmmcd
Points: 3,013, Level: 33
Points: 3,013, Level: 33 Points: 3,013, Level: 33 Points: 3,013, Level: 33
I also had this problem, but only one time so far. 2012 3GT 4-dr with about 75k miles. I do a lot of highway and use the cruise quite often. It was really cold out (15 deg F or so) and I thought it just had to do with that. After shutting off car and restarting, it worked and never had the issue since. Huh.
dmmcd is offline
post #16 of 22 (permalink) Old 09-17-2016, 05:04 PM
Kjaxela3
Points: 7,512, Level: 57
Points: 7,512, Level: 57 Points: 7,512, Level: 57 Points: 7,512, Level: 57
Kjaxela3's Avatar
I'm having this problem as well. Has anyone found the problem yet?
Kjaxela3 is offline
post #17 of 22 (permalink) Old 09-24-2016, 10:59 AM
dkenitz
Points: 1,840, Level: 25
Points: 1,840, Level: 25 Points: 1,840, Level: 25 Points: 1,840, Level: 25
My 2012 sky hatch started having this issue about 6 months ago. It would happen maybe once a month but started occurring more frequently. Now, it happens almost daily after the first start in the AM. It is really frustrating in this car because if you turn the ignition off and back on at speed (car is manual) the electric power steering goes awry. Having to stop is really inconvenient but so is not having CC on a 50+ mile highway drive.
dkenitz is offline
post #18 of 22 (permalink) Old 09-26-2016, 10:24 PM
GreatWhiteApeND
Points: 452, Level: 9
Points: 452, Level: 9 Points: 452, Level: 9 Points: 452, Level: 9
Activity: 29%
this reminds me of the problem subarus had with 02 sensors, bad gas and a finicky emissions system.. but at least their problem flashed the cruise light and turned on MIL.
11 3 i touring
GreatWhiteApeND is offline
post #19 of 22 (permalink) Old 02-08-2017, 03:48 AM
dkenitz
Changed my battery recently...problem gone!!
dkenitz is offline
post #20 of 22 (permalink) Old 02-08-2017, 05:49 PM
kms1990
Demon Spawn
Points: 4,709, Level: 43
Points: 4,709, Level: 43 Points: 4,709, Level: 43 Points: 4,709, Level: 43
Activity: 58%
Activity: 58% Activity: 58% Activity: 58%
kms1990's Avatar
I read on another mazda forum the cruise acting up in this manner could be the symptom of a failing battery. I would suggest anyone with this issue before trying anything drastic, running off to the stealer or spending any money simply disconnect your battery for a few minutes (10-15 is usually good) and then reconnect and then take the car and have the battery tested. you maybe surprised and find you have a bad battery, and a battery can be failing and "bad" before it wont crank the car. if it wont charge up like normal its is going bad, if the sides are swelling, its bad, if it takes longer then normal to crank, battery could be going bad (could be starter or wires/relay too, but wont get into that here) if your battery tests fine wait and see if the cruise acts up again, if not then it just needed a reset, if it does further diagnostics are needed these cars, like many today have overly complicated electrical systems and its not always easy to pin down problems like these to any one thing
"Give into the Night"
kms1990 is offline
control , cruise , engage
