Spare Tire Questions - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
post #1 of 8 (permalink) Old 02-08-2010, 11:15 AM Thread Starter
Furnace
Points: 2,044, Level: 27
Points: 2,044, Level: 27 Points: 2,044, Level: 27 Points: 2,044, Level: 27
Sadly I woke up this morning to a flat front tire. I swapped out the tire with the space saver spare and was about to drive to work, when I though, maybe I'll check the manual out for a sec.
Well, to my surprise, I found out the manual states:
Do not install the temporary spare tire
on the front wheels (driving wheels):
Driving with the temporary spare tire
on one of the front driving wheels is
dangerous. Handling will be affected.
You could lose control of the vehicle,
especially on ice or snow bound
roads, and have an accident. Move a
regular tire to the front wheel and
install the temporary spare tire to the
rear.
Also, in my manual (which is in the car), there was a blurb about limited slip differentials and how you should never use a space saver spare on it. The electronic copy of the manual (which is probably US based) doesn't have this blurb in it.
Do our cars have a limited slip diff in the front? I didn't think so.
Also, any harm in using the spare up front?
Furnace is offline
post #2 of 8 (permalink) Old 02-08-2010, 11:29 AM
StitcH
Moderator
Points: 13,671, Level: 76
Points: 13,671, Level: 76 Points: 13,671, Level: 76 Points: 13,671, Level: 76
StitcH's Avatar
Send a message via AIM to StitcH
The LSD essentially works by gauging large differences in speed between the left and right wheels (assuming it is a torque-sensitive LSD, not a geared LSD). If one wheel is spinning much faster than the other, the LSD engages and tries to get them to spin at the same speed. So you can imagine the spare would have to spin much faster than the full size to maintain the same speed. This would cause the LSD to engage and force it to work VERY hard and, if driven long enough, prematurely fail.
The MS3 does, the regular MZ3 does not. I think there is something in the manual by that note that says "for 2.3L engine." Maybe not.
I would think the only harm would be terrible speedometer/odometer readings and poor traction. I could be wrong though. If I were in the same situation, I would jack one side of the car and, using jack stands, put a rear tire on the front and the spare on the rear.
StitcH is offline
post #3 of 8 (permalink) Old 02-08-2010, 12:27 PM
myt_tuf1
2010 MS3
Points: 8,344, Level: 61
Points: 8,344, Level: 61 Points: 8,344, Level: 61 Points: 8,344, Level: 61
myt_tuf1's Avatar
+1 Especially if there is snow or ice present!
2010 MS3 (Black)|DDM 6000K|Rally Armor Flaps|Turbosmart BPV|Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP/CBE/Tow Plate|H&R Springs|Koni Yellow|ETS 3.25 TMIC|Cobb AP|Denso ITV22|TS RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Hankook Ventus V12 Evo K110 235/45-17|SURE IM/TB TIG|Hella Supertones
myt_tuf1 is offline
post #4 of 8 (permalink) Old 02-08-2010, 12:59 PM
BSUBigMac
Points: 14,297, Level: 77
Points: 14,297, Level: 77 Points: 14,297, Level: 77 Points: 14,297, Level: 77
BSUBigMac's Avatar
Yes, there is a reason they state to never put a donut on the front! Speaking from years of experience working in a garage that mainly did tires (NTB to be exact) I've seen lots of people come in with damaged tires because they drive like normally and not extra careful. The donut on the front will hurt handling, turning, and is much, much worse in the snow and ice, even the cold.
If you turn too sharp, turn to quickly, or even accelerate too quickly you can actually pull the tire off the wheel. They seem to seat differently and they are a very, very high profile so they just act differently.
Do what everyone else recommends, put the spare on the back and rotate a good tire to the front! It is a little more work but better than getting in an accident, or driving into the garage with just a metal rim!!!
Never settle for mediocrity!
2010 4-Door Graphite Mica Mazda 3i Touring
Mods: 20% tint, Xenon Expert aluminum pedals, zoom-zoom decal, CorkSport SRI, 55w 4300k DDM Tuning HIDs, CorkSport LED Lighting Kit, V-LEDs 5k LED Trunk Light
BSUBigMac is offline
post #5 of 8 (permalink) Old 02-08-2010, 01:34 PM
Desertnate
Points: 5,248, Level: 46
Points: 5,248, Level: 46 Points: 5,248, Level: 46 Points: 5,248, Level: 46
Another problem with running the spare on the front drive wheels could come from transmission damage from the drive wheels not being the same diameter.
In an automatic transmission Subaru for instance, they tell you if you have a flat to ensure the front axle has two normal tires on it and then pop a special fuse which kills the power to the rear axle and turns the car into FWD. If you have a manual, you are just hosed and have to drive only a very short distance because the AWD system is different.
Desertnate is offline
post #6 of 8 (permalink) Old 02-10-2010, 08:24 AM
alphadog
Points: 2,313, Level: 29
Points: 2,313, Level: 29 Points: 2,313, Level: 29 Points: 2,313, Level: 29
Activity: 50%
Activity: 50% Activity: 50% Activity: 50%
The space saver spares are made to get you to safety, not for daily driving. They usually have a top speed of 45 mph and some have a 50 mile distance limit. lf you have a flat and have to get home put the spare on the front - especially if it is only a few miles - there won't be any damage if you take it slow and drive home or to a repair shop.
alphadog is offline
post #7 of 8 (permalink) Old 02-10-2010, 09:23 AM
BSUBigMac
BSUBigMac's Avatar
I think you said it well!
post #8 of 8 (permalink) Old 02-10-2010, 10:21 AM
wkarno2
Points: 4,363, Level: 42
Points: 4,363, Level: 42 Points: 4,363, Level: 42 Points: 4,363, Level: 42
Wow wish i had known this a couple months ago. I hit some glass in the parking lot of my apartment and had to put on the spare. luckily it was warmer. It was the first time id ever had a flat actually. i was on one hand smart enough not to to over 45, turn hard, accelerate hard or do anything more than slow and easy grandma driving because of how nervous it made me and i got it changed in like 3 days. but i wish i had k known about switching them around i hope i didnt do any damage unintentionally, the shop didnt say anything but who knows.
wkarno2 is offline
questions , spare , tire
