Dyno+tron+ics - 2010-13 Mazda 3/Mazdaspeed 3 Forums
Go Back   2010-13 Mazda 3/Mazdaspeed 3 Forums > 2010-2013 Mazda 3 & Skyactiv News & Discussion > 2010-2013 Mazda 3 & Skyactiv Engine and Performance
Old 07-06-2012, 01:37 AM
OrangeVirus1 OrangeVirus1 is offline
Banned
Points: 9,008, Level: 63
Points: 9,008, Level: 63 Points: 9,008, Level: 63 Points: 9,008, Level: 63
OrangeVirus1 is a jewel in the roughOrangeVirus1 is a jewel in the roughOrangeVirus1 is a jewel in the roughOrangeVirus1 is a jewel in the rough
Default Dyno+tron+ics
hey, question for your expertise...
Since installing my new primary 02, it seems my ecu is cutting fuel like hell from the FIC when going into boost..
even with my 600cc injectors, and setting it at +70% duty cycle the ecu still can pull enough fuel to bring the afrs up to like 13.8.. that's at like 2psi, haven't gone higher in psi range because the afr's already..
how can I get around this...
probably gonna call tripoint tomorrow ask how they managed around it.. but wanted your insight aswell if you care to share
Old 07-06-2012, 01:54 AM
Crespo's Avatar
Crespo Crespo is online now
College Zoom-Zoom
Points: 10,791, Level: 68
Points: 10,791, Level: 68 Points: 10,791, Level: 68 Points: 10,791, Level: 68
Crespo is a name known to allCrespo is a name known to allCrespo is a name known to allCrespo is a name known to allCrespo is a name known to allCrespo is a name known to all
Maybe a fuel pump upgrade will solve this? How sure are you that it is the ECU?
^^^My build thread^^^
Click the picture, you know you wanna...
>>>Mod of the Month<<<
Have something you want to sell on the forum? Abide by the rules.
http://mazda3revolution.com/forums/b...e-posting.html
Old 07-06-2012, 02:25 AM
Banned
because it wasn't doing it when I had my dead 02 sensor in the car.. it was just open loop all the time which let me control fuel completely.. but also SUCKS because the weather changed my tune !
Old 07-06-2012, 11:27 AM
Dynotronics1 Dynotronics1 is offline
Points: 2,949, Level: 33
Points: 2,949, Level: 33 Points: 2,949, Level: 33 Points: 2,949, Level: 33
Dynotronics1 will become famous soon enoughDynotronics1 will become famous soon enough
It wasn't an open loop all the time it was in default mode. Which made it run on a fixed map and let you get away with trimming fuel. The W RAF cannot be fooled by the Piggyback last time I checked because it's not voltage related but current.
Old 07-06-2012, 12:12 PM
Banned
yeah your right,from what I read online, it sends a pos/neg signal not a voltage.. no signal @ stoich, neg sig at rich, pos signal at lean... not really sure it can be fooled by anything....
ahh.. I'll figure a way around it. stil think it's crazy the ecu can adjust for 70% more fuel then stock pulse.. wth!
Old 07-06-2012, 02:40 PM
DL2011MS3's Avatar
DL2011MS3 DL2011MS3 is offline
Dustin L.
Points: 2,366, Level: 29
Points: 2,366, Level: 29 Points: 2,366, Level: 29 Points: 2,366, Level: 29
DL2011MS3 will become famous soon enough
Find out what resistance that O2 sensor normally puts for a good reading and put an inline resistor. Bypass the sensor completely. Temporary fix till u get the actual problem solved.
Old 07-06-2012, 04:05 PM
Sorry won't work; ecu knows about what the current should be for any given situation. It checks against a known map vs air flow/load.
If you really want to run a tunable set up you are going to have to run a stand alone in parallel set up. Trouble with this is you lose dbw, abs, and traction control
Old 07-06-2012, 05:18 PM
Banned
I got around it, Just added more fuel then the ecu could cut, eventually I overrid the ecu.. with +80-90%.. good solid 12.0 afrs in boost now.. I'm surprised, i'm can keep up with my buddies speed 6 he only gets about car length on me.. until 5th gear he wins
Old 07-06-2012, 05:37 PM
3i2011's Avatar
3i2011 3i2011 is offline
Points: 12,332, Level: 72
Points: 12,332, Level: 72 Points: 12,332, Level: 72 Points: 12,332, Level: 72
3i2011 is a glorious beacon of light3i2011 is a glorious beacon of light3i2011 is a glorious beacon of light3i2011 is a glorious beacon of light3i2011 is a glorious beacon of light
Dyno time
Mods: TSW Trackstar 5 Wheels (16x7 +50, Stock 205 55 16 Tires) | Advance Timing | Simota SRI (CBII-657) | 20% Tint | Interlagos (VW Plaid) Interior Trim
Wishlist: MSDS Header | Racing Beat ABE
Old 07-06-2012, 06:19 PM
no you didn't. Ya think you did, but keep running with the trims at -25 and your not going to be happy.
Besides, WTF would you want to run an a/f of 12:1 on a turbo?!
dyno, ics, tron
