How to install MSDS header - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
post #1 of 8 (permalink) Old 07-21-2014, 06:12 PM Thread Starter
dudemanbro
Points: 2,736, Level: 31
Points: 2,736, Level: 31 Points: 2,736, Level: 31 Points: 2,736, Level: 31
When I ordered my header, it didn't come with any instructions and I couldn't find any guides with pictures or video, so I made one. I'll write out the basic steps, but here is a link to the video I made:
https://www.youtube.com/watch?v=l8A4...ature=youtu.be
Basic steps:
1. Jack up the front of your car and put it on jack stands.
2. Disconnect the negative terminal of your battery (since we are going to be unplugging sensors).
3. Crawl under the car and unbolt the downpipe of the factory exhaust manifold from the catalytic converter. Also pull the downpipe out of the hangers.
4. Back under the hood, unbolt the top heat shield. There are two bolts on top and two on each side.
5. Unclip the two sensors.
6. Under the car again, there are two bolts that secure the manifold to the motor. Unbolt those. In fact, if you can get in there, just take that shelf out. Totally pointless once we take out the factory manifold.
7. You may want to unbolt the bottom heat shield, too, while you're down there. We ended up taking that off to squeeze the manifold out.
9. Under the hood again, there are 7 nuts securing the manifold to the motor. Take those off.
10. You should now be able to pull the manifold out. Like I said, we ended up taking off the lower heat shield to give us more room to work with. We also took off the manifold gasket because it has a lip on the top that got in the way.
11. With the manifold out, you can remove the O2 sensors. You might need to use some PB Blaster to coax them out.
12. Put some anti-seize compound on the threads of the sensors and install them onto the new header. You don't really need to torque them down, just make sure they are nice and tight.
13. Slide the downpipe on to the header, but don't tighten it down yet.
14. Put a new gasket on the motor and slide the header into place. You will probably either need a friend to help or you will be going back and forth between the hood and under the car trying to wiggle it into place.
15. Secure the header to the motor with the 7 nuts. There's a diagram in the video that shows the right order. Most of these are accessible with a torque wrench, but again, just make sure they are good and tight.
16. Clip the sensors back in.
17. Go back under the car and bolt the downpipe to the cat. Also slide it into the hangers.
18. Now that everything is where it needs to go, tighten the bolt to secure the downpipe to the header. With that stupid shelf from earlier out of the way it shouldn't be too hard to access.
You're done! Keep in mind you will get a check engine light now that you are missing a cat. Dynotronics can take care of that with a tune.
dudemanbro is offline
The Following User Says Thank You to dudemanbro For This Useful Post:
sbag0024 (07-29-2014)
post #2 of 8 (permalink) Old 07-21-2014, 06:13 PM Thread Starter
dudemanbro
Ah damn, can a mod move this to the 2010-2013 Mazda 3 section instead of the Speed 3 section? My bad.
post #3 of 8 (permalink) Old 07-22-2014, 01:14 PM
Crespo
College Zoom-Zoom
Points: 19,491, Level: 88
Points: 19,491, Level: 88 Points: 19,491, Level: 88 Points: 19,491, Level: 88
Activity: 31%
Activity: 31% Activity: 31% Activity: 31%
Done.
^^^My build thread^^^
Click the picture, you know you wanna...
Have something you want to sell on the forum? Abide by the rules.
Crespo is offline
post #4 of 8 (permalink) Old 08-01-2014, 03:38 PM
Joel
Points: 5,678, Level: 48
Points: 5,678, Level: 48 Points: 5,678, Level: 48 Points: 5,678, Level: 48
Activity: 6%
Joel's Avatar
Do we need to purchase a new gasket from where the header connects to the motor? Where can I get one?
Im afraid of breaking the sensors. How difficult were they?
Sent from: Rose City, Oregon.
2011 CWP Mazda 3 Sport in Portland, OR!
Check out my progress:
Joel is offline
post #5 of 8 (permalink) Old 08-01-2014, 05:50 PM
pdc001
Points: 66,608, Level: 100
Points: 66,608, Level: 100 Points: 66,608, Level: 100 Points: 66,608, Level: 100
pdc001's Avatar
Gasket you can get from the dealer. Some people have used the old gasket with no issues if you want to take a chance at it. PB blast the o2 sensors and let it sit for a bit and then use a o2 socket. The rear sensor you can take it off after you remove the OEM. Done this twice already.
pdc001 is online now
post #6 of 8 (permalink) Old 08-02-2014, 07:06 AM Thread Starter
dudemanbro
Even the factory gasket is only maybe $30, so there's really no reason not to buy one. Better safe than sorry.
The sensors really aren't that bad. I left them both in until I took the manifold out, as you can see in the video, and the bottom one pretty much just came right off. The top one was a little more stuck, but that's mostly because it's buried down in a weird little well.
@pdc001 : What did you do with that little cup that's attached to the upper sensor? I just left it on because I couldn't figure out how to get it off, but it looks pretty stupid and I've been thinking about just cutting it off.
post #7 of 8 (permalink) Old 08-02-2014, 11:33 AM
pdc001
pdc001's Avatar
That little cup is part of the sensor, its like a shield for the sensor itself.
The Following User Says Thank You to pdc001 For This Useful Post:
dudemanbro (08-02-2014)
post #8 of 8 (permalink) Old 08-02-2014, 11:57 PM
Kjohn63
ZOOM'IN around Mid-Ohio
Points: 3,452, Level: 36
Points: 3,452, Level: 36 Points: 3,452, Level: 36 Points: 3,452, Level: 36
Kjohn63's Avatar
Replace the gasket, learned the hard way..
K&N SRI.
MSDS Header.
DynoTronics Tuned
Magnaflow CBE.
Megan Strut tower.
C/S RSB. Koni ST-R
R/B F/S links, Tri-pt R/S links.
E-Focus RMM.
EMUSA Rear Camber.
Tein Stech springs.
Slotted/drilled Rotors, Ceramic pads.
Conti EC DW on MS3 Rims Summer, Falken Azenis PT722 on Stock Rims winter.
50/5 Tint, Blue interior LEDs, 7500k High/low/fog and other stuff
2012 Mazda 3s 2.5
Kjohn63 is offline
header , install , msds
