Clicking from Climate Controls - Page 3 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
post #21 of 31 (permalink) Old 11-22-2013, 02:16 PM
Hschlick84
Points: 5,975, Level: 50
Points: 5,975, Level: 50 Points: 5,975, Level: 50 Points: 5,975, Level: 50
Hschlick84's Avatar
I can check for it, should be listed in the warranty information based on the VIN number through the dealer.
2010 Mazda 3 2.5 S Black Mica 5dr
Corksport LED kit | 35% tint | Lamin-X foglight tint | OEM all season mats | OEM cargo net | OEM bumper protector| Corksport mudflaps | Broadway mirror | VMS racing 3" antenna | LED 3rd brake light | Thule Aeroblade roof rack | K&N drop filter |
Hschlick84 is offline
post #22 of 31 (permalink) Old 01-19-2014, 04:14 AM
fr2004
Points: 62, Level: 1
Points: 62, Level: 1 Points: 62, Level: 1 Points: 62, Level: 1
I have the same problem. Ticking noise coming from the dashboard. Esp when I turn on AC. Does anybody know what part needs to be replace. Thanks in advance.
fr2004 is offline
post #23 of 31 (permalink) Old 02-03-2014, 11:29 AM
fateexceeds
ZOOM ZOOM
Points: 6,117, Level: 50
Points: 6,117, Level: 50 Points: 6,117, Level: 50 Points: 6,117, Level: 50
fateexceeds's Avatar
Send a message via AIM to fateexceeds
I had mine replaced under my extended warranty at my local Mazda dealership last year. According to the invoice, the part is called the "fresh air intake actuator". The part number is BBY4-61-B60, and it costs $80.10.
Current mods: CorkSport SRI // CorkSport strut tower bar // Tri-Point RSB // Tri-Point endlinks // JBarone short shift kit // DDM pedals // OEM footwell LED lights // OEM all-weather floormats // Tenzo Tracer V1 Black Matte 18x8.5 +48 // Kumho Ecsta LX Platinum 225/40R18 // McGard SplineDrive wheel lock kit // 35% window tint
Future mods: Road Magnet 1.25" springs // Koni Sports // CorkSport CBE or Racing Beat ABE // door vent visors
fateexceeds is offline
post #24 of 31 (permalink) Old 10-16-2014, 01:21 PM
rudy81
Points: 42, Level: 1
Points: 42, Level: 1 Points: 42, Level: 1 Points: 42, Level: 1
This happens to intermittently in my 2013 Mazda 3 Sky and my girlfriend's 2010 Mazda 3. I told the dealership about it but they say they can't do anything unless it's actually see/hear the problem. It doesn't happen very often to either of us, maybe once a month for a couple of hours, but it is really annoying.
rudy81 is offline
post #25 of 31 (permalink) Old 12-20-2014, 05:10 PM
WheelMcCoy
Points: 4,068, Level: 40
Points: 4,068, Level: 40 Points: 4,068, Level: 40 Points: 4,068, Level: 40
WheelMcCoy's Avatar
2010 Mazda3 here. I had this happen a couple of times and I traced is to some debris caught in the fan vent. I tried to clear it by setting the fan to high (4) and changing the vent adjustments -- high, low, etc -- and that seemed to clear it.
I don't know if the debris got blown out or was broken into smaller pieces.
WheelMcCoy is offline
post #26 of 31 (permalink) Old 02-20-2017, 12:02 PM
americankgb
Points: 4,822, Level: 44
Points: 4,822, Level: 44 Points: 4,822, Level: 44 Points: 4,822, Level: 44
I had the actuator motor issue and replaced it myself. I took the bad one apart to see if I could figure out what the issue is.
All of the gears were in good shape and still had a decent amount of factory grease left. Looks like the problem is the motor. I hooked it up to an arduino and it sounds terrible when it's running as opposed to the new motor which runs silently. All of the images were taken after i stripped the factory grease to inspect the gears.
I'll post a video later.
ID:	197402   Click image for larger version
ID:	197410   Click image for larger version
ID:	197418   Click image for larger version
americankgb is offline
post #27 of 31 (permalink) Old 02-21-2017, 10:11 AM
kms1990
Demon Spawn
Points: 4,921, Level: 44
Points: 4,921, Level: 44 Points: 4,921, Level: 44 Points: 4,921, Level: 44
Activity: 37%
Activity: 37% Activity: 37% Activity: 37%
kms1990's Avatar
you guys with this issue, I am wondering if this is not partially due to lack of cabin air filter change. These are easily overlooked, and kind of a pain on our cars, so they may get overlooked or not done even by the mazda techs themselves, if the cabin air filter clogs it still has to get air so it will just suck in that dirt and crap all in the filter after awhile. I bought my 2011 used last year and the cabin air filter in it was disgusting. I don't think it had ever been changed and the car was at 62k miles when I checked it. the manual recommends changing the cabin air filter every 24k miles, might be worth doing/checking if you have this issue, may help prevent more.
"Give into the Night"
kms1990 is offline
post #28 of 31 (permalink) Old 03-30-2017, 09:21 AM
BJMac
Points: 10, Level: 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Is this actuator accessible through the glove box?
BJMac is offline
post #29 of 31 (permalink) Old 03-30-2017, 03:23 PM
simbatran
Points: 181, Level: 3
Points: 181, Level: 3 Points: 181, Level: 3 Points: 181, Level: 3
Activity: 11%
It would be a lot more helpful if the actual video of removing/installing the blend door actuator is posted, if not, some detailed descriptions can also be helpful. There are quite a number of existing threads describing the issue which should be well understood by now. My 2010 Mazda 3 makes the same clicking noise when the Air Refresh Circulation button is turned OFF. I had the cabin air filter replaced where I found a lot of leaves and junk, but that did not help at all. Mazda Dealer estimate is $750, mostly labor cost to open the dashboard.
For now, I just leave the Air Refresh Circulation button ON all the time. The vents still blow properly to the correct places, so it is not so bad to live with.
Also one important details is how to align the new actuator hand with the current position of the blend door.
simbatran is offline
post #30 of 31 (permalink) Old 04-01-2017, 10:49 AM
WheelMcCoy
WheelMcCoy's Avatar
Originally Posted by simbatran View Post
... I had the cabin air filter replaced where I found a lot of leaves and junk, but that did not help at all. Mazda Dealer estimate is $750, mostly labor cost to open the dashboard.
2010 Mazda3 here. I changed the cabin filter myself without removing the glove box. The video shows how although it's a bit hard to make out some details, and you need to stick your head in an awkward space (passenger side foot well).
https://youtu.be/iJeUX7r_5J4
Filter, OEM or after-market, is about $20. First time took me an hour, but now I can do it less than 30 minutes (I take the time to vacuum the compartment). Yes, 24 months is about right. I cooridinate the change with my engine air filter so my car and I can both breathe better.
clicking , climate , controls
