Has anyone heard of a camber kit for the 2010 MZ3 yet? I dropped the car about 2 inches all around and now my tires are angled in on the top, its only a little but it will eventually wear out the tires unevenly.
I'm dropped and I installed SPC adj camber links. I bought them from SPC Camber Arm: MS3, Mazda 3 or you could buy Mazdaspeed fixed links. http://www.streetunit.com/MAZDASPEED_3_Rear_Camber_Links_p/grms-8m-l07.htm You gotta know what your camber is at now to know whether you need fixed or adj. The fixed bring your camber out 0.9 degrees from where your at now. So If your not that bad now it may be to much. The adj you can set them wherever you want. Autox like them because you fine tune oversteer and understeer with them in addition to making low offset wheels just tuck in behind the fenders.
