Ads Do Not Appear For Registered Users. Click here to register!
Go Back   2010 Mazda 3/Mazdaspeed 3 Forums > Mazda 3 and Mazdaspeed 3 Discussions > Mazda 3 News & Discussion > 2010+ Mazda 3 Discussion > 2010+ Mazda 3 How-To Guides
Connect with Facebook
Old 07-06-2009, 06:22 PM
glennk's Avatar
Points: 3,694, Level: 38
Points: 3,694, Level: 38 Points: 3,694, Level: 38 Points: 3,694, Level: 38
glennk will become famous soon enough
Arrow 2010 MAZDA 3: Wimpy Horn Upgrade
2010 Mazda 3: Wimpy Horn Upgrade
Time to build the new wiring assembly: 15 - 30 minutes
Time to install the additional horn: 30 - 45 minutes
Tools needed:
Wire Stripper
Flash light
Phillips Head screw driver
10mm Ratchet
Parts needed:
Assorted Quick Disconnects (with ends that can be crimped)
14 Gauge Automotive Wiring
Electrical Tape (recommend Scotch 33+, temp range is from sub-zero to 221 degrees)
Low tone horn (I chose the cheap $15 FIAMM Freeway Blaster)
For the wiring harness, I used to two 3” equal pieces of 14 Gauge automotive wiring.
Twist the two end pieces together and carefully place the MALE disconnect over the wire and crimp. Use the FEMALE disconnects on the other two ends. As a side note (for safety sake), I wrapped all of the connects with electrical tape just to make sure everything was secure. (Forgot to take a pic, so I borrowed the one above from the Mazda3Forums)
INSTALLATION
Step 1 - Under the right side of the vehicle (directly behind the fog light), remove the three screws holding the plastic flashing cover to the vehicle.
Step 2 - Push back the piece of plastic
Step 3 - Look past the plastic housing shielding the fog light.
Step 4 - See the horn? Looks very similar to the prior generation of the Mazda 3.
Step 5 & 6 - Remove the plug from the current horn by depressing the center plastic piece on the plug (yes, I was a moron sitting there tugging and complaining. lots of creative language was used until common sense kicked in)
Step 7 - I chose to leave the bracket attached to the car, instead removing the bolt attaching the horn. Attach the ground plug to the new horn (read instructions for which pole is positive and negative) and loosely connect the extension bracket (depending on what vehicle you have, you may need to jockey the horn into a new position). I held the old horn, grounding plug and extension bracket (with the second horn attached) together at the screw attachment (connected to the original horn) and carefully pushed everything up and into the car. I re-attached the nut and adjusted the horns to fit within the cavity. (If you are having difficulty moving around, you can disconnect the two power cables for the Fogs to the left. The plastic clip easily came loose and re-attached easily after I had the horns mounted.) TAKE YOUR TIME, AS THIS IS SLIGHTLY FRUSTRATING. SPACE IS LIMITED.
Step 8 - You can now see everything is connected up and tightened into place. I have my horns facing directly down (toward the ground)
Step 9 - (no pic included, sorry) I attached the female connectors to the horns (push ‘em all the way on). Now, connect the male to the power wire coming from the car (this should have a CLICK sound. Be careful, this is a live wire. No need to disconnect the power, if you are careful)
Step 10 - (no pic included) Re-apply the plastic flashing cover with the Phillips head screws. YOU ARE DONE.
NOTE TO SELF: This new horn combination is SUPER LOUD. Don’t be an idiot like me and test the new horn in an enclosed space (garage). I about deafened myself.
Good luck to y’all! With a bit of patience and about $20 bucks, you too can improve your wimpy horn setup!
Glenn
Dallas, TX
P.S. Instructions written for previous generation 3's were of good help! See them at the following locations:
A beginner's guide to Upgrading the whimpy stock HORN - w/ pics
Our horns, high or low?
The Following 7 Users Say Thank You to glennk For This Useful Post:
Derrick_B (07-06-2009), dimachka (02-20-2010), igotzzoom (07-07-2009), josh (07-06-2009), mymx6 (07-29-2009), pepperdro (03-03-2010), stealthmidget (01-30-2010)
Old 07-06-2009, 06:47 PM
Derrick_B's Avatar
Resident MacGyver
Points: 6,539, Level: 52
Points: 6,539, Level: 52 Points: 6,539, Level: 52 Points: 6,539, Level: 52
Activity: 90%
Activity: 90% Activity: 90% Activity: 90%
Derrick_B has a spectacular aura aboutDerrick_B has a spectacular aura aboutDerrick_B has a spectacular aura about
Send a message via ICQ to Derrick_B Send a message via AIM to Derrick_B Send a message via Yahoo to Derrick_B
Thanks for the write-up
Btw, just copy the URL from your pic (right-click on it in the web page when you're viewing it and go to properties) and insert using the icon in the editor.
Like this...
http://mazda3revolution.com/forums/m...al-product.jpg
Becomes this...
The Following User Says Thank You to Derrick_B For This Useful Post:
glennk (07-06-2009)
Old 07-06-2009, 07:30 PM
glennk's Avatar
Big thanks to you Derrick! Changes made!
Old 07-06-2009, 07:55 PM
igotzzoom's Avatar
Points: 1,157, Level: 18
Points: 1,157, Level: 18 Points: 1,157, Level: 18 Points: 1,157, Level: 18
igotzzoom is on a distinguished road
So...forgive me if I'm being extra-dense...did you simply add a second horn to the factory one, or did you replace both the factory one and add a second one with a twin set?
Old 07-06-2009, 09:17 PM
glennk's Avatar
I added a second horn to the factory one. No, you are not "extra-dense"...just asking a good question.
Old 07-06-2009, 10:17 PM
Points: 894, Level: 15
Points: 894, Level: 15 Points: 894, Level: 15 Points: 894, Level: 15
Zlog is on a distinguished road
Thats a really nice write up. I'm NOT a car person (I'm a computer tech) and honestly probably couldn't change my oil (hopefully that's an exaggeration). With these instructions i'm totally confident i'll be able to get this working by myself!
Did you add on just the low-tone or a second high-tone? Also, if i wanted to replace the factory horn as well as add in a second horn would i need to do anything different besides removing the factory horn? Would there be any concerns with the wiring/voltages or is the factory horn a 12v as well?
Thanks again!
Old 07-06-2009, 10:44 PM
glennk's Avatar
Thanks again!
Low-tone Freeway Blaster added to the stock high tone unit. Both are made by FIAMM. No other changes are required if you want to replace the factory horn and add a second. Remember, the fuse is limited to 15A. Don't exceed this or you will have to make more electrical changes.
Old 07-07-2009, 12:35 AM
Derrick_B's Avatar
Resident MacGyver
Activity: 90%
Just finished this mod a few minutes ago. I have a few comments.
  • You also need a 8mm socket to remove the splash guard. The 10mm is for the horn.
  • I do not recommend removing the bracket. I thought I'd give it a try, but it was just too much of a PITA to reinstall with the horns on it. I took the horns off, re-mounted the bracket, and finished it.
  • Overall, not too bad, but there is very limited space to work with. I'd say it's better if you drive the car up on ramps or put the front end on stands. I dunno. Either you're a contorsionist or I did something wrong, lol.
  • Use this as an opportunity to get a good set of crimpers. I've used the cheap ones before and they will straight-up destroy connections (notice the difference in my connections and the ones in the other pic). Good crimpers will not and they last forever. I prefer the simple ones like this: - Harbor Freight Tools - Quality Tools at the Lowest Prices
Also, here's a pic for you to replace the one from the other site. I'd rather keep this a M3R article
Good mod. I'm happy with the results. It sounds like a real car now!
The Following 2 Users Say Thank You to Derrick_B For This Useful Post:
glennk (07-07-2009), josh (07-07-2009)
Old 07-07-2009, 01:06 AM
Homer3D's Avatar
Points: 998, Level: 16
Points: 998, Level: 16 Points: 998, Level: 16 Points: 998, Level: 16
Homer3D is on a distinguished road
you wouldn't have a before and after video of how it sounds, would you?
Old 07-07-2009, 01:10 AM
glennk's Avatar
Excellent! Thanks Derrick! I have put your pic up in place. There are several ways to complete this update (attached other options at the end of my original post). This is an annoying but necessary upgrade. Most folks don't take the OEM horn serious. I went out this evening had my first opportunity to put my new combo to use. Needless to say, it definitely satisfied my needs.
2010, horn, mazda, upgrade, wimpy
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0 ©2009, Crawlability, Inc.
