usb ports are useless - Page 2 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 8Likes
post #11 of 25 (permalink) Old 03-13-2017, 11:06 AM
harweyko
Points: 1,609, Level: 23
Points: 1,609, Level: 23 Points: 1,609, Level: 23 Points: 1,609, Level: 23
Hmm, european models switch off the cigarette lighter once engine is turned off, I use it as camera source.
Regarding USB charging, yes, 0.5A is slow, 1.5A would be better, but than someone will cry that he has QC2 or QC3 or VOOC or some other fastcharge technology in his phone and that he wants the one he uses to be implemented. So rather buy power source that suits your needs than ask car producer to implement billion types of possible services that are at the end used by few users..
harweyko is offline
post #12 of 25 (permalink) Old 03-13-2017, 12:29 PM
GerryB
Working Class Hero
Points: 5,998, Level: 50
Points: 5,998, Level: 50 Points: 5,998, Level: 50 Points: 5,998, Level: 50
GerryB's Avatar
A dual USB adapter for the 12v socket works pretty well.
Sent from a Samsung that doesn't explode.
GerryB is offline
post #13 of 25 (permalink) Old 03-13-2017, 01:02 PM Thread Starter
car0800
Points: 859, Level: 15
Points: 859, Level: 15 Points: 859, Level: 15 Points: 859, Level: 15
Activity: 13%
Originally Posted by Valor_X View Post
Why complain?
The main focus of the USB ports are for media use, not to charge your device
Plug in a separate charger in the 12v power port like I did
my flash drives with music take up the USB ports anyway
The center console even has a hole to pass a cable through it with the lid closed.. so I would think that they did actually think about it
because the 12v port is always on and I have to plug in and remove it manually whenever I park to prevent it from nuking the charger or worse the recepticle because it's continuously on 24/7.
I disagree that the ports are only for music and not charging... this is not the design of other cars i've seen. In addition USB 3 has been around for years now and it specifies a minimum charging current of 900 mA so it's not even that. Yes, it's a small issue but the segment is absolutely cut throat and if the car maker wants to stay ahead of the curve they need to pay attention to all these details, especially if Mazda wants to improve market share.
car0800 is offline
post #14 of 25 (permalink) Old 03-13-2017, 01:14 PM
Valor_X
Points: 3,185, Level: 34
Points: 3,185, Level: 34 Points: 3,185, Level: 34 Points: 3,185, Level: 34
Activity: 17%
Activity: 17% Activity: 17% Activity: 17%
I've left mine plugged in for 2 years and nothing has happened
The only thing that happens is the little led power indicator stays on - that's not enough to drain the battery
In fact, I have a Noco Genius 3500 that I plug in every now and then to check my battery and it's always near 100%
2014 Soul Red Mazda3 Sedan i Grand Touring
5000k HID Low Beams and Fog Lights
HID Projector Fog Light Housings
Philips Diamond Vision 5000K High Beam Bulbs
DRL LED C-Shaped Fog Light Covers
Cree LED bulbs for Map/Dome lights
LED Vanity lights
Custom 48SMD LED Panel for trunk lighting
LED License Plate bulbs
LED Reverse Lights
3.5" PowerBass Coax Dash Speakers
Rockford Fosgate R500X1D / Powerbass 12" Sub
Debadged Skyactiv/Mazda3 emblems
OEM Door Sills
Valor_X is offline
post #15 of 25 (permalink) Old 03-13-2017, 02:33 PM
ElNino77
Points: 4,528, Level: 42
Points: 4,528, Level: 42 Points: 4,528, Level: 42 Points: 4,528, Level: 42
ElNino77's Avatar
I used to use the cig lighter but removed the adapter after a long trip during "clean out mode" and have been using the USB since - has not bugged me enough to add back the cig adapter.
I did install an additional usb port to the left of the steering wheel - here's an old pic, it's since been mounted in a different spot flush against underside of dash - i believe i wired this to a fuse that turns on/off with car IIRC. Note this is strictly for power, not hooked to stereo - i wonder if there are usb outputs on back? There are on my cheapo BOSS stereo in my forester...can hook just about anything up to that thing.
ElNino77 is offline
post #16 of 25 (permalink) Old 03-13-2017, 02:43 PM
BrianU
Points: 1,530, Level: 22
Points: 1,530, Level: 22 Points: 1,530, Level: 22 Points: 1,530, Level: 22
Activity: 21%
Activity: 21% Activity: 21% Activity: 21%
If I NEED to really charge my phone during high period of demand that the internal USB ports cannot provide, I use this:
Aukey CC-T8 Car Charger with Dual Quick Charge 3.0 Ports
2016 Touring manual Deep Crystal Blue Mica/Sand leatherette
35% 3M Ceramic film|OEM cargo tray, F&R splash guards|TPI C726445F Wheel Locks|Interior & BKup LEDs|iJDMTOY Fogs yellow Lamin-x & H9s Mazda stalk|H9 headlights
A119 dashcam w/GPS & Lexar microSDXC 633x 128GB|Polk Audio DB351s/100V 47uF caps in dash|DXI 651s rear doors|Kenwood KSC-SW11 subwoofer|Thermoquiet acoustic insulation
BrianU is offline
post #17 of 25 (permalink) Old 03-13-2017, 08:39 PM
mil
Points: 1,069, Level: 17
Points: 1,069, Level: 17 Points: 1,069, Level: 17 Points: 1,069, Level: 17
Actually, the built-in USB ports are 1000mA, not 500. But, being USB 2.0 ports, intelligent devices like cell phones automatically limit themselves to only draw 500mA, as mandated by the USB specs.
What you need is a dedicated charging-only USB cable (you know, with data wires shorted, Google it if you don't know what I mean) and then the cell phone will be happy to draw 1A.
ElNino77 likes this.
mil is offline
post #18 of 25 (permalink) Old 03-14-2017, 09:56 AM
da_jokker
Points: 4,416, Level: 42
Points: 4,416, Level: 42 Points: 4,416, Level: 42 Points: 4,416, Level: 42
I have to agree with the OP... I also figured that I could just plug my phone in. After all, with other cars making use of Apple\Android "play" and all other technologies, I figured I just needed to plug my phone in. Seems like it is enough to keep your phone from going dead (say as you are driving around or on a road trip), but doesn't seem to output enough to actually charge the thing withing any reason.
In other recent threads, sounds like Mazda may be coming out with Apply Play. So how is that going to work with a non-charging USB port? I also know there is an Android Auto "aftermarket" add on.. again doesn't these require the USB cable?
Just saying, would it have killed Mazda to allow up to 1.5 or 2 amps on a USB port, especially with USB being the prominent connector of the mass electronics out there now. I like Mazda (so much I own 2 of them).. but it's all this little stuff where they cut corners that is really starting to add up against them.
da_jokker is offline
post #19 of 25 (permalink) Old 03-14-2017, 10:04 AM
Izacus
Points: 721, Level: 14
Points: 721, Level: 14 Points: 721, Level: 14 Points: 721, Level: 14
The problem is, that there's no >500mA charging spec over USB 2.0 (the ones installed in your Mazda). All the fast-charging specs before USB 3.0 are proprietary and differ between manufacturers (e.g. one for Apple iPhones, one for Samsungs, etc. etc.) and most of them don't allow you to charge and send data over the cables at once (Apple's spec and some of the bleeding edge Qualcomm specs being special). That's probably the reason why only 500mA ports are installed and that probably won't change until USB-C ports are in there
Izacus is offline
post #20 of 25 (permalink) Old 03-14-2017, 11:46 AM
TN3239
Points: 270, Level: 5
Points: 270, Level: 5 Points: 270, Level: 5 Points: 270, Level: 5
I have the same issue where the USB port can't charge my phone faster than it uses power while using Google Maps. Found instructables. com/id/USB-Condom/ that I'm going to try out today.
TN3239 is offline
ports , usb , useless
