Premature Rear Brake Wear (2.5 GT) - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 1Likes
  • 1 Post By kas
post #1 of 10 (permalink) Old 04-21-2017, 03:22 PM Thread Starter
seanc81
Points: 7,627, Level: 58
Points: 7,627, Level: 58 Points: 7,627, Level: 58 Points: 7,627, Level: 58
seanc81's Avatar
Hey Guys!
For starters i'm not heavy on the brake pedal, in fact, I tend to downshift using the paddle shifters (especially when i'm getting off the highway).
Now that I've cleared that up, lol, I've had nothing but issues with brakes on my 2014 Mazda 3 GT from the day i've owned this car.
I've had countless front pads replaced, rotors...the whole nine yards.
At 40K I was told that my rear pads were "low". At the time, all 4 rotors & front pads were being replaced under warranty so I decided to pay a few hundred and replace the rear pads.....so everything would be brand new...why not right?
Great, so, now at 77K and my rear pads are grinding like a mofo....metal to metal. How can this be? This is my 14th new car which i've owned and I've never had to replace brakes so fast like this...ever.... Its as if the front pads are doing nothing, (because there is like 60+ % left) and what I find strange is that the front rotors keep warping....you'd think it would be the rears at this point since they 'seem' to be doing more work.
Any other GT owners with this issue? There is absolutely no way I am paying to have them replaced (again).
seanc81 is offline
post #2 of 10 (permalink) Old 04-21-2017, 05:36 PM
wolstentech
Points: 2,086, Level: 27
Points: 2,086, Level: 27 Points: 2,086, Level: 27 Points: 2,086, Level: 27
Activity: 19%
Rotors warping? Is your mechanic properly torquing the lug nuts? That's usually caused by uneven and excessive lug nut torque. It cost you "a few hundred" to replace the rear pads? That's a lot of money for some brake pads. Are you sure they even replaced them?
Maybe you should find a new mechanic.
wolstentech is offline
post #3 of 10 (permalink) Old 04-21-2017, 09:47 PM
Points: 2,845, Level: 32
Points: 2,845, Level: 32 Points: 2,845, Level: 32 Points: 2,845, Level: 32
Originally Posted by seanc81 View Post
Hey Guys!
Pay several hundred for new rear pads? It was all apart anyhow, so maybe $100 extra in parts and labor?
As for the rest, there a couple possibilities.
The front calipers may be sticking, causing the front brakes to get too hot and not work. This would be why the rears pads are gone so fast and why the rotors wear quickly.
Most warped rotors are not warped. When the brakes get hot, pad material transfers to the rotor. If the pads are hot and the wheel stops turning, a heavy patch of pad material may be deposited on the rotor. Several patches of varying thickness may be spread around the rotor, and you will feel these deposits as vibrations. These vibrations are usually attributed to warped rotors.
There may be a problem with the master cylinder causing the brakes not to release fully. This will also cause poor brake performance and short brake life.
The brake system should have some sort of proportioning valve. If the rear brakes are getting more pressure than the front, they will do more work, and since the rear pads are smaller they will wear out much faster.
post #4 of 10 (permalink) Old 04-21-2017, 11:35 PM
kas
Points: 2,242, Level: 28
Points: 2,242, Level: 28 Points: 2,242, Level: 28 Points: 2,242, Level: 28
There is a TSB for uneven rear pad wear due to the hardware causing pad binding. It would depend on your VIN but 14s were covered.
Road Trip likes this.
kas is offline
post #5 of 10 (permalink) Old 04-22-2017, 01:27 AM
The Following User Says Thank You to arathol For This Useful Post:
Big_Nebrowski (05-02-2017)
post #6 of 10 (permalink) Old 04-28-2017, 03:49 PM Thread Starter
seanc81
seanc81's Avatar
Rotors were warped from factory when I picked up my car. All my brake work has been done at Mazda.
seanc81 is offline
post #7 of 10 (permalink) Old 04-28-2017, 03:55 PM Thread Starter
seanc81
seanc81's Avatar
Thanks for the info, I think it was $180 or something like that for the pads...anyway, trust me when I say my rotors have been warped several times......bad pulsation even at slow speeds.....
It's going back in on Monday, we shall see. One things for sure, I am not gonna pay for pads (again).
The lease ends in a year, can't wait for a new car.
seanc81 is offline
post #8 of 10 (permalink) Old 05-02-2017, 12:38 PM Thread Starter
seanc81
seanc81's Avatar
Good news. Dealer was awesome and took care of the issue. Replaced rear pads, rotors and some bracket that attaches to the caliper. $0. No more grinding
seanc81 is offline
post #9 of 10 (permalink) Old 05-02-2017, 03:24 PM
darvetis
Points: 2,678, Level: 31
Points: 2,678, Level: 31 Points: 2,678, Level: 31 Points: 2,678, Level: 31
Activity: 27%
Activity: 27% Activity: 27% Activity: 27%
darvetis's Avatar
Fantastic!!!!!!
darvetis is offline
post #10 of 10 (permalink) Old 05-02-2017, 08:03 PM Thread Starter
seanc81
seanc81's Avatar
Beyond fantastic, since I have 78,000KM on the car
seanc81 is offline
brake , premature , rear , wear
