What STB and RSB pick? - Page 2 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 6Likes
post #11 of 18 (permalink) Old 02-03-2017, 06:00 PM
Moto-x_Mike
Points: 3,212, Level: 35
Points: 3,212, Level: 35 Points: 3,212, Level: 35 Points: 3,212, Level: 35
Activity: 40%
Activity: 40% Activity: 40% Activity: 40%
I've had the Progress RSB for 2 years & haven't changed the endlinks. No problems so far, even after adding Racing Beat springs & Koni FSD's.
Moto-x_Mike is offline
post #12 of 18 (permalink) Old 02-03-2017, 07:32 PM
Points: 2,177, Level: 28
Points: 2,177, Level: 28 Points: 2,177, Level: 28 Points: 2,177, Level: 28
Originally Posted by Jet3 View Post
Thanks to all for the answers!
Ok, sorry for the ignorance. But what happen if i don't upgrade the endlinks? The Eibach springs lowered just 1.3 inches in the rear.
I decided go for the Progress RSB. Wich Endlinks (apart of the ebay) are trustworthy? Moog? Hardrace? Is just 2 endlinks for the rear, right?
Thanks and sorry for my english!
The factory links are somewhat weak. The much higher spring rates of aftermarket bars (~340 lbs vs 700+ lbs) can damage the joints which apparently are held together by those orange plastic tabs.
If you lower the car and don't use adjustable links, there can be a couple issues. The swaybar will be angled upward too much, and the ends can hit the floorpan if you hit a large bump. This was actually a problem with my car (lowered 45mm in the rear) before the adjustable links were installed. If the angle of the bar relative to the motion of the rest of the suspension is wrong, you won't get optimum effect. The bar should be as close to horizontal as possible. You can see that in the picture above.
Here is a graphic from Hardrace showing the problem:
Use whatever endlinks you like. The ebay ones are plenty strong and not expensive though. Yes, it is just 2 endlinks for the rear bar.
Moval likes this.
arathol is online now
post #13 of 18 (permalink) Old 02-05-2017, 07:44 PM
Moval
Points: 499, Level: 9
Points: 499, Level: 9 Points: 499, Level: 9 Points: 499, Level: 9
If you stick with the stock endlinks, you will only be able to use the softer setting on the rear sway bar. That's if you have lowering springs installed.
To use the stiffer setting you need to be on stock springs (stock ride height) or install adjustable rear endlinks when you are lowered.
Read post 17-
http://mazda3revolution.com/forums/2...problem-2.html
Jet3 likes this.
Moval is offline
post #14 of 18 (permalink) Old 02-08-2017, 01:35 PM Thread Starter
Jet3
Points: 995, Level: 16
Points: 995, Level: 16 Points: 995, Level: 16 Points: 995, Level: 16
Activity: 40%
Originally Posted by arathol View Post
Endlinks? Yes, especially if you are lowering the car you should use adjustable endlinks to keep proper positioning of the bar. Stronger endlinks are also a good idea because the stock parts are not really up to the task of handling the higher spring rates of a larger bar.
These work and are quite a bit heavier than stock:
Adjustable Sway Bar Links for Mazda 3 BK 2004 2009 | eBay
Get whatever bar you like. They are mostly the same, just a rate difference that you probably won't really notice a whole lot.
Ok, i got it! I'm trying to buy the RSB in the Progress website, but in the last step i dont know what happen.
This is the same for the 2015, right?
https://www.carid.com/progress-group...19&url=6827240
About the endlinks, are you sure the Ebay endlinks (ADJUSTABLE SWAY BAR LINKS FOR MAZDA 3 BK 2004-2009 | eBay) are for the 2015? The announcement says they are for the 2004-2009 and for the Front Sway bar.
Thanks again to all!
Jet3 is online now
post #15 of 18 (permalink) Old 02-08-2017, 06:25 PM
RSB is the same for all 3rd generation cars. I think that website may not be up to date.
The description for the endlinks says for 2004-2009 but as you can see in the picture they do fit my 2016. Those have a huge range of adjustment with three different length adjusters. As such, they will fit many different cars. I have these on both the front and rear sway bars.
Jet3 likes this.
post #16 of 18 (permalink) Old 02-08-2017, 08:09 PM Thread Starter
Jet3
Activity: 40%
Red face
Perfect!
One last question (i hope so )
What about this websites? They are trustworthy?
Progress Technology Anti-Sway Bar - Rear, Mazda Mazda3 14-15 (22mm-adj) - Part Number: 62.1127 - Sparktec Motorsports - Anti-Sway Bars
https://www.tunersports.com/progress...27_p52675.html
Greetings from Perú!
Jet3 is online now
post #17 of 18 (permalink) Old 02-08-2017, 09:07 PM
Hmm...never heard of either one. Can't hurt to try.
post #18 of 18 (permalink) Old 02-25-2017, 11:13 PM
damekko
Points: 2,492, Level: 30
Points: 2,492, Level: 30 Points: 2,492, Level: 30 Points: 2,492, Level: 30
Activity: 13%
Bought my progress RSB from: https://thmotorsports.com/ $149 dlls with shipping included. Took a week to arrive to Mexico city
damekko is offline
pick , rsb , stb
