Best Endlinks for Eibach Springs and Progress RSB - Page 3 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 10Likes
post #21 of 49 (permalink) Old 03-20-2017, 08:34 PM
DMshadow
Points: 4,357, Level: 42
Points: 4,357, Level: 42 Points: 4,357, Level: 42 Points: 4,357, Level: 42
Activity: 11%
DMshadow's Avatar
You see the potential issue I see? Could be easily solved and not what I had thought.
ID:	200082   Click image for larger version
Moval likes this.
DMshadow is offline
post #22 of 49 (permalink) Old 03-20-2017, 08:45 PM
savalee101
Points: 858, Level: 15
Points: 858, Level: 15 Points: 858, Level: 15 Points: 858, Level: 15
savalee101's Avatar
You do have the washer on that lower end of the endlink lol. That's definitely the issue. Take that washer out! Not needed
savalee101 is offline
post #23 of 49 (permalink) Old 03-20-2017, 08:53 PM
DMshadow
Activity: 11%
DMshadow's Avatar
Looks like the shop put it in all 4. Wonder if I can get them to do it for me they've been trying to adjust them as I have issues for free. I have ramps and jackstands but I don't have a low enough jack for the car now. Whole lot of headache for some washers
DMshadow is offline
post #24 of 49 (permalink) Old 03-20-2017, 10:31 PM
Points: 3,298, Level: 35
Points: 3,298, Level: 35 Points: 3,298, Level: 35 Points: 3,298, Level: 35
Yeah that would do it.
Make them fix it right.
post #25 of 49 (permalink) Old 03-20-2017, 10:46 PM
DMshadow
Activity: 11%
DMshadow's Avatar
From the pics I only see the one, I'll have to check tomorrow when there is more light because it seems odd it would only be in the one spot and on the side I am not currently having issues with. Im thinking top link drivers side given the rub ring.
DMshadow is offline
post #26 of 49 (permalink) Old 03-20-2017, 11:15 PM
The lower ends of both look screwed up. One obviously has the flange washer, and on the other the nut is clearly not tightened against the mount. One thing that bothers me is in both pictures you can clearly see where vicegrips have been used. On one side the washer is all gouged up. You can't keep the stud from turning by gripping the flange washer like that. On the other side the lower flange on the stud itself is marked the same way. That is a good way to poke a hole in the rubber boot. You need to use a thin wrench to hold flats on the inner part of the stud. That is really the only way to do it right.
See what I mean?
I'd take it back and tell the guy to take it apart, do it right, remove the flange washers and lose the vice grips.
post #27 of 49 (permalink) Old 03-20-2017, 11:30 PM Thread Starter
Jet3
Points: 1,180, Level: 18
Points: 1,180, Level: 18 Points: 1,180, Level: 18 Points: 1,180, Level: 18
So, when i will install my endlinks (ebay), has to be without the washers?
Jet3 is offline
post #28 of 49 (permalink) Old 03-20-2017, 11:33 PM
savalee101
savalee101's Avatar
Yes no washer.
Jet3 likes this.
post #29 of 49 (permalink) Old 03-21-2017, 09:08 AM
DMshadow
Activity: 11%
DMshadow's Avatar
See what I mean?
Yeah I see all of that, the pass side like the right is all the way down, you're seeing that second bolt I was talking about. So to get it right they gripped the crap out of the opposite side and put the second one on. I'll discuss this with them, I shouldn't have a problem getting it done properly.
DMshadow is offline
post #30 of 49 (permalink) Old 03-21-2017, 12:02 PM
Make sure you discuss the use of proper tools, ie the right type of wrench to hold the rear of the stud, not vice grips.
eibach , endlinks , progress , rsb , springs
