Rear Sway Bar Info - Page 11 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 30Likes
post #101 of 110 (permalink) Old 02-14-2017, 01:30 PM
Moto-x_Mike
Points: 3,402, Level: 36
Points: 3,402, Level: 36 Points: 3,402, Level: 36 Points: 3,402, Level: 36
Activity: 26%
Activity: 26% Activity: 26% Activity: 26%
If you have well-designed normal brackets like Progress uses, then I think the billet brackets are unnecessary.
Moto-x_Mike is offline
post #102 of 110 (permalink) Old 02-14-2017, 02:59 PM
Points: 3,298, Level: 35
Points: 3,298, Level: 35 Points: 3,298, Level: 35 Points: 3,298, Level: 35
Originally Posted by SirDuckferd View Post
it seems like a lot of folks have problems with clunking and noise
Mostly due to improper installation, not design issues.
If you use the right endlinks, grease the bushings and torque the fasteners properly you should be ok.
post #103 of 110 (permalink) Old 02-15-2017, 12:35 PM
Digital Skyline
Points: 188, Level: 3
Points: 188, Level: 3 Points: 188, Level: 3 Points: 188, Level: 3
Digital Skyline's Avatar
How do front and rear sway bars affect snow/ice driving? I'm leaning towards getting these but don't want make my winter driving any more difficult!
Thanks
Digital Skyline is offline
post #104 of 110 (permalink) Old 02-15-2017, 01:42 PM
They don't.
You don't need a larger front for street driving.
post #105 of 110 (permalink) Old 02-18-2017, 02:29 PM
EdwinB
Points: 129, Level: 2
Points: 129, Level: 2 Points: 129, Level: 2 Points: 129, Level: 2
Was reading but didnt seem to see anyone change the endlinks before adding the progress sway bar, would it be recommended to do so or is it fine to not change it?.
EdwinB is offline
post #106 of 110 (permalink) Old 02-18-2017, 04:24 PM
Really?? Where have you been looking? Lots of posts on that too.
Here are three I found with a couple minutes of searching-
http://mazda3revolution.com/forums/2...-rsb-pick.html
http://mazda3revolution.com/forums/2...end-links.html
http://mazda3revolution.com/forums/2...sb-struts.html
post #107 of 110 (permalink) Old 02-19-2017, 02:43 AM
SirDuckferd
Points: 238, Level: 4
Points: 238, Level: 4 Points: 238, Level: 4 Points: 238, Level: 4
Activity: 85%
Activity: 85% Activity: 85% Activity: 85%
I am buying my Progress RSB within a few weeks (have been busy taking advantage of the warm weather on weekends motorcycling =D) but their website states that it's designed for use with the stock endlinks. I'll probably be giving them a call to confirm. I'm going to guess that whether you need endlinks is, "it depends".
My personal thoughts are that the endlinks were designed for OEM spring rate and ride height, so they could be strained (tension) by a stiffer RSB; but at the same time, if you're not doing anything else with your suspension (lowering) that would cause binding or unnecessary additional strain, the benefit of adjustable links in particular can be dubious. The endlinks are fairly easy/cheap to replace so if you know you're not going to do anything else with your suspension and you're using the progress RSB on soft setting, forget about it unless your OEM ones are shredded already for whatever reason. If you know you're going to be doing other suspension modifications, then invest in them right off the bat.
SirDuckferd is offline
post #108 of 110 (permalink) Old 02-19-2017, 01:48 PM
The stock endlinks are weak. They are held together by those orange plastic bits you see on the back. Much stiffer bars such as the Progress will overstress those weak links and they can fail. When replacing the OEM bar you should use stronger endlinks. If you are changing the ride height, you need adjustable links. The sway bar is supposed to be in a certain position relative to the rest of the chassis and suspension to work properly. Once you lower the car those relative positions change and you get a decrease in functionality.
The Following User Says Thank You to arathol For This Useful Post:
Midnightsky228 (06-14-2017)
post #109 of 110 (permalink) Old 06-14-2017, 12:51 AM
Midnightsky228
*The Electrician*
Points: 756, Level: 14
Points: 756, Level: 14 Points: 756, Level: 14 Points: 756, Level: 14
Midnightsky228's Avatar
What is a good quality endlink to use with the Progress RSB? Preferably something not found on ebay.
1993 Honda Civic Si SOLD
1995 Toyota Celica GT SOLD
1995 Acura Integra RS SOLD
2002 Acura RSX Base SOLD
1995 Subaru STi Type RA SOLD
2004 Honda Accord 2.4L SOLD
2017 Mazda 3 Hatch 2.5L Winters Moonlight
Midnightsky228 is offline
post #110 of 110 (permalink) Old 06-14-2017, 12:59 AM
Actually, Ebay seems to be the best place in this case. The German Racing Parts endlinks are real beefy and not expensive. In fact, Scale used to carry the same ones for their suspension at twice the cost.
bar , info , rear , sway
