What handles better stock 16 inch or 18 inch? - Page 2 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 4Likes
post #11 of 23 (permalink) Old 03-16-2017, 06:31 PM Thread Starter
Martin2000GTS
Points: 303, Level: 6
Points: 303, Level: 6 Points: 303, Level: 6 Points: 303, Level: 6
Activity: 95%
Activity: 95% Activity: 95% Activity: 95%
Great info guys. thank you very much! I think I'm going to look into an after market light weight 17 or 18" wheel. Thanks!!
Martin2000GTS is offline
post #12 of 23 (permalink) Old 03-17-2017, 09:30 AM
da_jokker
Points: 4,416, Level: 42
Points: 4,416, Level: 42 Points: 4,416, Level: 42 Points: 4,416, Level: 42
18" will handle better for 2 reasons..
1 - Lower profile tires with smaller sidewalls = less flex (but harsher ride)
2 - Given two setups of the same diameter and weight, the one that has more of it's weight on the outside will suffer. Therefore Tire weights comes into play and typically a low profile 18" tire will weight less than 16" with larger sidewalls and more rubber. The wheel itself, although bigger and maybe a bit heavier, distributes that weight overall and not just on the circumference.
Now before getting slammed... note # 2 (of the same weight). So if you go from say a 30 lbs 16" (just making up the numbers) to a 40 lbs 18" .. then the 16's would handle better.
Road Trip likes this.
da_jokker is offline
post #13 of 23 (permalink) Old 03-17-2017, 12:15 PM
dradernh
Points: 2,501, Level: 30
Points: 2,501, Level: 30 Points: 2,501, Level: 30 Points: 2,501, Level: 30
Originally Posted by da_jokker View Post
Given two setups of the same diameter and weight...typically a low profile 18" tire will weight less than 16" with larger sidewalls and more rubber
It's been my understanding that due to more steel being required to maintain the shape of the lower-profile and stiffer tire, an 18" unit would typically weigh more than its 16", same-diameter counterpart.
Can you give us one or more examples of 16" and 18" tires that we might reasonably choose for our MZ3s where the 18" tire weighs less than the 16" tire, including the brand and model? Or, maybe, where they weigh the same.
dradernh is offline
post #14 of 23 (permalink) Old 03-17-2017, 01:12 PM
Points: 2,223, Level: 28
Points: 2,223, Level: 28 Points: 2,223, Level: 28 Points: 2,223, Level: 28
Thats not how it works at all. Wheels are unsprung weight. It does not matter how the weight is distributed. Heavier wheels mean the suspension is slower to react. A slow moving suspension means the car won't handle or ride as well as it could.
Lower profile does not necessarily mean a harsher ride or less flex. This is entirely dependent on tire construction. For example, the Conti DW has notoriously soft sidewalls. Even the low profile sizes flex a lot. The new Conti ECS has an 86% improvement in sidewall stiffness and the higher profile sizes are quite a bit stiffer than the low profile DWs.
Heavier construction makes the weight difference between profile sizes pretty minimal. Generally when upgrading from 16" to 18" rims the tires are substantially wider, so the tires end up a pound or two heavier anyhow.
Here is a typical example:
Dunlop Signature HP- OEM size 205/60R/16 is 20 lbs. The smallest 18" size available, 215/45R/18, is OEM for the Mazda 3 and weighs 22 lbs.
post #15 of 23 (permalink) Old 03-17-2017, 02:02 PM
MeteorGray
Points: 2,347, Level: 29
Points: 2,347, Level: 29 Points: 2,347, Level: 29 Points: 2,347, Level: 29
Activity: 90%
Activity: 90% Activity: 90% Activity: 90%
If I drove on a smooth race track at high speeds, I would select wide, low-profile tires with large-diameter alloy wheels. Their race-proven design is ideal for that type of environment.
However, I primarily drive at highway speeds on public highways that are becoming increasingly rough every day. At highway speeds there are limited things I can do to avoid potholes and other road irregularities and still maintain safe lane discipline. So, I chose the 16-inch rims which take tires that provide more cushioning effect on the road, even though today they are not considered as stylish.
I also chose the 16-inch factory alloy wheels because they are lighter than the steelies. And although the factory alloys are often a few pounds heavier than some of the sleeker aftermarket models, they are very robust and take the hits well. I've heard stories of some light aftermarkets failing when put to the test against potholes at speed.
My OEM 16" alloy wheels with the stock Yoko P205 60R 16 tires are reasonably light at about 39 pounds each. I think they give me the best performance for my driving environment. So far, so good.
MeteorGray is offline
post #16 of 23 (permalink) Old 03-17-2017, 04:25 PM
Road Trip
Experienced Gearhead
Points: 2,877, Level: 32
Points: 2,877, Level: 32 Points: 2,877, Level: 32 Points: 2,877, Level: 32
Road Trip's Avatar
I agreed that lowering unstrung weight is a key to better handling -- and why many race cars even more their shocks inboard.
The question however I feel is paramount, what is our intended use for our cars? If we are auto crossing, racing on a traditional race track, or are driving at 8/10's+, better handling is hugely important.
However, to be honest with ourselves, how many of us have the courage to drive our cars at better than 7/10's (other than a really intermittent romp on an interstate ramp or similar). I go for drives with many of my sports car friends, and being candid here, for most of them their car's capabilities are so, so far in excess of the both their driving skills and also their courage take a turn at anywhere near their car's capabilities.
As an example, I am track trained/experienced, and my Z06 (which has a heads up display with a "G meter"), will do 1.14G, whereas our Mazda's do around .84G. Do I ever, on even my favorite, totally-isolated, curvy country road exceed .95 G? NO, I do not. (Though I do have the courage to drive at 1.10+G on a race track with huge/safe run off areas.)
So which is more important to you, IMO the better looks of an 18"+, and paying (if you choose wisely) just a few pounds weight penalty, or additional, more than our Mazda's .84G handling capability, that most never use nor need?
Jan. 25th ordered Mazda 3 GT hatch; Feb. 3rd allocation awarded; Feb. 8th official options/color confirmed; Feb. 27th assembly completed; April 1st scheduled for boarding onto transporter Ro-Ro; April 15th ETA at Port of Tacoma; 1st week of May ETA for dealership arrival.
Below picture thanks and credit to Skagerstrom, for that is his beauty below, the inspiration for what our car will look like.
Road Trip is offline
post #17 of 23 (permalink) Old 03-17-2017, 04:57 PM
Well, actually, going from 50+ lbs per corner to about 37 on a fairly light car like the Mazda 3 makes a huge difference across the board, not just at race speeds. Most people notice the difference right away. The suspension works so much better, the car rides better and feels lighter. Those OEM 18" boat anchor wheels should be the first thing to kicked to the curb.
post #18 of 23 (permalink) Old 03-17-2017, 06:06 PM
Road Trip
Road Trip's Avatar
Oh yes. I can not imagine how much more poorly an extra 13 pounds per corner would affect even day-to-day handling.
Most however would not notice 2 or even 3 pounds per corner unless tracking or similar. Hell, many drivers drive around with some tires seriously underflated, others overinflated and never even notice. A driver study about a year ago found that 33% of American drivers admitted to driving around for several weeks or more with a check engine light without doing anything. Very sad.
Just yesterday leaving a store, I hear this horrible, to me unmistaken sound, saw it was a totally flat rear tire of a Ford P-U being driven by a man about 50 years old, with someone who looked like his son in the passenger seat. I drove after them for about a mile, trying to get their attention (they were going the same direction as I was), and when they finally got to the cell phone store they were heading to, I pulled up near them, walked over and asked, "Hi, there, do you know you have a flat tire?" Driver said, "no." His passenger said, "no." And they both walked back about 30' toward the truck with a look on their faces, "can't be, let's check and see if that guy is telling the truth."
post #19 of 23 (permalink) Old 03-17-2017, 06:19 PM
dradernh
Looking at stopping distances, what's important to me in the context of the .84g skidpad result is that the 18" OEM tires have a 'B' traction grade (more here: https://www.tirerack.com/tires/tiret...&affiliate=EB8). That translates to poor stopping distances in the wet, which concerns me greatly as the car is my wife's daily driver. At 182', the stopping distance in the dry isn't anything to write home about either. Fortunately, she drives at the speed limit or slightly below it.
This.
For summer use only, to improve both handling and stopping via weight reduction and stickier rubber I have the following combinations on my radar screen. The prices are mounted, balanced, and delivered from the Tire Rack.
The first of those is the most practical package. The light weight and much lower price of the Kosei/ECS combo is certainly attractive, even if its 1" drop isn't.
dradernh is offline
post #20 of 23 (permalink) Old 03-17-2017, 08:11 PM
I have been checking out the ECS too. They seem to run wide as many performance tires do. I think TireRacks numbers are more in line with industry standards not the actual tire size. Those who have them already say that the 205s seem somewhat wide, and would probably work even on an 8" rim. I'll be putting the 205/50 17s on 7.5" TrakLite Gears very soon, next week maybe if it warms up a bit.
handles , inch , stock
