Chris_Top_Her Build Thread 2 - Page 3 - 2004 to 2016 Mazda 3 Forum and Mazdaspeed 3 Forums
 3Likes
post #21 of 43 (permalink) Old 02-28-2015, 11:19 AM
EWitsSEAN
Points: 3,504, Level: 37
Points: 3,504, Level: 37 Points: 3,504, Level: 37 Points: 3,504, Level: 37
EWitsSEAN's Avatar
Originally Posted by gsk3rd View Post
Whats the point of the camber arms? To give you more camber?
It's to adjust your camber to correct wheel alignment or if you want to adjust it to your liking for track and all that.
EWitsSEAN is offline
The Following User Says Thank You to EWitsSEAN For This Useful Post:
gsk3rd (02-28-2015)
post #22 of 43 (permalink) Old 02-28-2015, 01:42 PM Thread Starter
chris_top_her
Points: 18,280, Level: 85
Points: 18,280, Level: 85 Points: 18,280, Level: 85 Points: 18,280, Level: 85
chris_top_her's Avatar
If you lower your car, which mine is, there is a good chance your rear camber will be out of spec since it's non adjustable. You need an adjustable arm to remedy this. Usually you end up with uneven camber, which wears out tires and changes handling.
chris_top_her is offline
The Following User Says Thank You to chris_top_her For This Useful Post:
gsk3rd (02-28-2015)
post #23 of 43 (permalink) Old 02-28-2015, 04:59 PM
gsk3rd
Points: 6,427, Level: 52
Points: 6,427, Level: 52 Points: 6,427, Level: 52 Points: 6,427, Level: 52
Is this something that can be added later without touching the springs or is one of those while your dropping the car you have to add them?
2015 Soul Red 3 SGT Hatch:
-50/35 Tint-CS SRI w/ K&N Heat Shield-CS Rear Sway Bar-Eibach Pro Springs-CF Interior wrap-Corksport LED Interior Kit-Sub added to stock Bose system-Red HUD display-Rokblokz flaps
gsk3rd is offline
post #24 of 43 (permalink) Old 02-28-2015, 06:01 PM Thread Starter
chris_top_her
You can do it later if needed. After you lower and get an alignment you may determine you don't need one.
post #25 of 43 (permalink) Old 03-13-2015, 06:53 PM Thread Starter
chris_top_her
Quick updates as I haven't been updating. A few days ago got into a fender bender, it's being fixed Monday.
post #26 of 43 (permalink) Old 03-13-2015, 06:56 PM Thread Starter
chris_top_her
Got my Crystal Eye LED's. Was going to wait to install them but I wanted them on now. I'm debating if I want to dip the bottom reflector, or I may just put some tint over it, which I got cheap on ebay. The lights have been wired into the third brake light, otherwise they won't brighten when you touch the brake. Very simple to install, the brake line was just an issue of wiring tapping, not much unlike installing dual horns (pre 2016). Only tools needed are a 10mm socket and a flathead for prying. Also at the same time the Whiteline sway bar brackets came, and the camber gauge now I'm just waiting on the coilovers to come in the mail.
post #27 of 43 (permalink) Old 03-18-2015, 06:16 PM
Leets
Points: 5,547, Level: 47
Points: 5,547, Level: 47 Points: 5,547, Level: 47 Points: 5,547, Level: 47
Activity: 11%
Leets's Avatar
I'm not usually a fan of clear taillights (still not even sure I like the OEM LED ones on my '12), but they just seem to work with the white. Clean without being too flashy.
Watching your build has got me thinking about a CX-5. I love my 3, but we're planning on the second child soon. The 3 is the perfect size for my taste, but with modern car seats I'm thinking I may need something just slightly bigger to fit two in back and still have room for 2 adults up front.
So, well done. You got me to consider something I never thought possible: a CUV.
Leets is offline
post #28 of 43 (permalink) Old 03-18-2015, 09:34 PM Thread Starter
chris_top_her
Thanks. They offer other trim/colors on this light. I don't think this version would go well with most other colors aside from a black cx-5. I don't want to drive a regular car because I don't like the seating position, and they typically won't accommodate my lifestyle and the things I want to be able to put in the back (like a bike). That being said my car based (mz6) cx-5 handles damn good. I have some BC coils in transit right now! The only disadvantage, which is minor compared to say the mz6 is I have a higher CG, which isn't a big deal, I can power slide (awd) this thing without even feeling a rolling moment.
post #29 of 43 (permalink) Old 03-18-2015, 09:35 PM Thread Starter
chris_top_her
post #30 of 43 (permalink) Old 03-20-2015, 02:32 AM Thread Starter
chris_top_her
Noticed I never posted my sway bar video..
feature
build , christopher , thread
