The mirror is so much win. aesthetically it may not be for everyone but function is win. install is a 5/10 it comes with everything just had to make one custom bracket to push it as far back as i wanted it. measured my fenders today after raising the car for my rims. F: 24" R: 22 3/4"
__________________ | |||||||||||||||||
Nice set up, I just have a few questions if you have some time... How did you wire up your LED strips to the trunk and rear armrest cubby? I was going to wire up some LEDs in the trunk from the wimpy factory light, but I was thinking 2 strips was a strech as far as wattage goes. Do you have all three of yours hooked up like that? As far as the rear armrest cubby I'm assuming you just drilled a little hole into the trunk (it seems pretty simple to go right through the seat but then you cant lay it down?) Thanks | ||||||||||||||||||
^ same, just put a dummy bulb in the stock hatch bulb location, the 3 strips probably use less power than the stock bulb... arm rest cubby?
Something new for the car
what did you use to paint the head/tail lights? I've got mine tinted but its just not doing it for me. (headlights are partial tint, just covering the turn signal) Only thing I'm not sure about is that its going to dim my HID's and I'm loving them right now. BTW.. this car is sick. its giving me alot of inspiration. | ||||||||||||||||||
all lights are automotive paint, had a body shop do them. If I had it to do again I would have baked and painted my headlights. The paint is cut out around the projector to allow normal light output.
Looks good, keep it up
__________________ Lowered Expectations | AutoProject | FurBallers | Street Unit 2010 Black Mica Mazda 3 Sport 2.5L Hatchback - Slammed and Flushed Daily Driver 1987 Crystal White Pearl Mazda Rx-7 FC3S S5 - Rebuilding, Track and Canyon | ||||||||||||||||||
| build, luc1f3r |
